April 8, 2015, 10:09 |
#21 |
mostafa
Rep Power: 13 |
hi every body
I have a problem with interpreting this UDF: ****************** #include "udf.h" DEFINE_PB_NUCLEATION_RATE(nuc, cell, thread) { #if !RP_NODE if ((C_VOF(cell,thread) > 0.05)) { C_UDSI(cell,thread,0)=C_VOF(cell,thread); . . . return (.....); #endif } ***************** the error is: Error: C:/Users/.... : line xx: label "store_vof_norm" not found (pc=74). please help me to solve this problem.:c onfused: |
April 8, 2015, 18:51 |
#22 |
Rep Power: 18 |
Try compiling the UDF instead of interpreting (some functions and macros require compiling rather than interpreting). If that fails, show us the entire UDF and error because where is it trying to access "store_vof_norm"?
April 14, 2015, 03:46 |
#23 |
mostafa
Rep Power: 13 |
hi harry
sorry that I was absent for some months, because I had an car accident. I found out the answer. the problem was from parallelization. when we use parallel run, some faces of some cells stored in another core of cpu and this make some problem. there is a remedy in ANSYS FLUENT Documentation named "parallel consideration". check that, it is very useful. |
April 14, 2015, 03:55 |
#24 |
mostafa
Rep Power: 13 |
Mr. 'e'
I'm modeling a three-phase problem with Eulerian (+Multi fluid VOF model) model. I also use Population balance model. I want to use a UDF for nucleation rate for third phase (second secondary phase). bellow are some part of this UDF: #include "udf.h" #include "sg_pb.h" #include "sg_mphase.h" DEFINE_PB_NUCLEATION_RATE(nuc, cell, thread) { real Epsilon_Entrainment; real Vof_CutOff; int phase1_domain_index = 0; int phase2_domain_index = 1; Thread *mixture_thread = THREAD_SUPER_THREAD(thread); Thread *ContinuousPhaseThread = THREAD_SUB_THREAD(mixture_thread,phase1_domain_ind ex); Thread *LargeBubbles = THREAD_SUB_THREAD(mixture_thread,phase2_domain_ind ex); Vof_CutOff= C_VOF(cell, LargeBubbles); if (C_U(cell,LargeBubbles) > 8) { Epsilon_Entrainment = 100000; } return (Epsilon_Entrainment); } But when I interpret this UDF, I encounter this error: Error: D:\\xxx: line 20: label "store_vof_norm" not found (pc=74). this UDF has 19 lines. this error refers to line 20.I found that this error is from sg_mphase.h file. In this file there is "store_vof_norm", But I don't know what is the problem???? |
April 14, 2015, 06:41 |
#25 |
Rep Power: 26 |
??? You say at 09:46 that you have the answer, and on 09:55 you ask exactly the same question as if you don't have the answer... ???
I would say that `e`'s comment from 9 april is still something you should do. |
April 14, 2015, 09:16 |
#26 |
mostafa
Rep Power: 13 |
no these two posts are for two different question.
I found the answer of the question that was asked some month ago and I discussed that with harry. and finally found the answer and wants to announce him in post number #23. but post numbers #21, #22 and #24 are about another question. I compiled my UDF as 'e' said, but the problem does not solved. |
April 14, 2015, 09:30 |
#27 |
Rep Power: 26 |
Ok I see now that it was two questions.
You say that compiling did not solve the problem, but you can give more information. Which error did you get upon compiling? |
April 14, 2015, 16:36 |
#28 |
mostafa
Rep Power: 13 |
actually it compiled. but after two steps of running segmentation error happened. I think this error is from multiphase thread assigning. do you know in parallel running how can I find the phase_domain_index of each phase in each computing node?
February 28, 2016, 18:04 |
#29 |
Hossein
Rep Power: 15 |
I searched through the entire forum, my problem still exists. I have reduced the code to just a simple code, but it seems it is not a compliation error (I have tried both interpreting and compiling). Here is the code:
/************************************************** ** ************* UDF for initializing phase volume fraction ************************************************** *** *************/ #include "udf.h" /* domain pointer that is passed by INIT function is mixture domain */ DEFINE_INIT(my_init_function, mixture_domain) { int phase_domain_index; cell_t cell; Thread *cell_thread; Domain *subdomain; real xc[ND_ND]; C_VOF(cell,cell_thread) = 1.; } and the error: Creating library libudf.lib and object libudf.exp Absorption.obj : error LNK2019: unresolved external symbol __imp__store_vof_norm referenced in function _my_init_function C:\PROGRA~1\ANSYSI~1\v160\fluent\fluent16.0.0\win6 4\3d\fl1600.lib : warning LNK4272: library machine type 'x64' conflicts with target machine type 'X86' libudf.dll : fatal error LNK1120: 1 unresolved externals However, my final goal after resolving the problem is to complie a code which calculates the absorption and scattering ceofficients for DO model, as a function of secondary phase vof thanks
Hossein Amini PhD student in Biochemical Engineering; Computational Science and Engineering department; North Carolina Agricultural and Technical State University |
February 29, 2016, 18:44 |
#30 |
Rep Power: 18 |
You've declared the variables 'cell' and 'cell_thread' but they have no values yet and you're trying to access them with C_VOF. These variables must be initiailised. You're probably intending to loop over the cells in your domain, try the thread_loop_c (for multiple thread zones) and begin_c_loop (for running through all cells in a thread) looping macros.
Convergence problem with target mass flow rate | ADL | FLUENT | 2 | May 29, 2012 21:11 |
UDF for inlet mass flow rate | rahulsuresh89 | Fluent UDF and Scheme Programming | 1 | October 16, 2010 17:06 |
UDF mass flow rate | Juan | FLUENT | 2 | December 22, 2007 09:29 |
particle, parcel and mass flow rate balance | flybird | FLUENT | 0 | May 24, 2007 10:44 |
How to define mass flow rate using UDF? | SAMUEL | FLUENT | 0 | December 16, 2004 02:55 |
