April 22, 2015, 01:58 |
#21 |
Rick
Rep Power: 27 |
From the definition I gave above, given a certain volume, the sphere is the solid which has the smallest surface area: having said that the maximum shape factor must be lower or equal to one (when you have spherical particle).
Maybe in that article you read authors give a different definition of "shape factor".
Google is your friend and the same for the search button! |
April 22, 2015, 02:06 |
#22 | |
S. Morichika
Rep Power: 12 |
" the ratio of the surface area of a non spherical nano particles to that of a spherical nano particles, where both of them are identical volume" |
April 22, 2015, 03:06 |
#23 |
Rick
Rep Power: 27 |
According to fluent that definition is 1/phi which in that case is always greater or equal to 1.
April 22, 2015, 03:53 |
#24 |
Rep Power: 27 |
"Shape factor" is a very general term. Maybe the literature defined it in a different way than Fluent. You should always check the definitions.
August 3, 2022, 17:10 |
#25 |
Rep Power: 4 |
Any update on this? How could the particles with different shapes be generated? Thanks |
How to define the size of particle in Eulerian | siara817 | STAR-CCM+ | 3 | January 15, 2020 15:40 |
how to define a shape deformation using the grid deformation variables (FSI problem) | momo_sjx | SU2 Shape Design | 6 | June 7, 2015 23:29 |
Check particle impaction with User Fortran | Julian K. | CFX | 3 | January 12, 2012 10:46 |
How to define Particle with UDF? | sega | Fluent UDF and Scheme Programming | 3 | January 20, 2010 05:50 |
how to define particle mass fraction in the subrou | Neser25 | CFX | 1 | October 6, 2005 10:20 |
