Compile/Interperet UDF--Fluent 14.5
Old   December 16, 2014, 11:42
Default Compile/Interperet UDF--Fluent 14.5
Schumacher00 is on a distinguished road
Hello Guys
Can anybody help me with this error below. (O.S:Unix)
I just tried both Interperet and Compile.It didn't work, Now this is the error poped up by Interpreting.
It has something to do with parallel setting of CPUs,As I'm using 7+1 Parallel CPUs.I would really apreciate it, if you could drop any Comments to this Problem.
Thanks in advance
Primitive Error at Node 2: error: udf compiler: unable to open udfconfig-node2.h for write
Primitive Error at Node 3: error: udf compiler: unable to open udfconfig-node3.h for write
Primitive Error at Node 4: error: udf compiler: unable to open udfconfig-node4.h for write
Primitive Error at Node 5: error: udf compiler: unable to open udfconfig-node5.h for write
Primitive Error at Node 6: error: udf compiler: unable to open udfconfig-node6.h for write
Primitive Error at Node 7: error: udf compiler: unable to open udfconfig-node7.h for write
Primitive Error at Node 0: error: udf compiler: unable to open udfconfig-node0.h for write
This is the error by Compiling:
Primitive Error at Node 6: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (lnamd64).
No such file or directory
/../home/.../YM/libudf/lnamd64/3ddp_node/libudf.so
Primitive Error at Node 7: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (lnamd64).
/.../home/.../YM/libudf/lnamd64/3ddp_node/libudf.so
Primitive Error at Node 0: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (lnamd64).
Error: The UDF library you are trying to load (libudf/lnamd64/3ddp_host/libudf.so) is not compiled for parallel use on the current platform (lnamd64).
no error
/.../home/.../YM/InitialStages/Stage1/Blade1/libudf/lnamd64/3ddp_host/libudf.so
Error Object: #f
Schumacher00 is offline   Reply With Quote
Old   July 14, 2015, 17:12
Default how you soved
ijaz fazil
er_ijaz is on a distinguished road
Can I know how you solved this issue
er_ijaz is offline   Reply With Quote
Old   July 14, 2015, 19:59
Hi er_ijaz,
1.Your Code should be in the same directory, in which your .cas and your .dat are locatedand. Also you have to start the fluent from the same directory. Otherwise a permission to write is needed, which in most cases normal users ofa cluster are not allowed for giving this permission.
2. Check for probable syntaxial errors in your code.==>> Debugging
I hope this could help you.
Regards
Wind turbine rotation through UDF in FLUENT Shamoon Jamshed Fluent UDF and Scheme Programming 10 June 25, 2018 13:58
fluent udf, saving data in udf mohsen zendehbad Fluent UDF and Scheme Programming 15 June 14, 2017 00:23
Making wave udf in fluent sunggun1212 Fluent UDF and Scheme Programming 7 October 27, 2015 11:52
DEFINE_DIFFUSIVITY udf in fluent maniek940 Fluent UDF and Scheme Programming 2 August 13, 2013 18:13
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 11:57
