C_STORAGE_R and SV_UDSI_M1
Old   December 11, 2014, 01:48
Default C_STORAGE_R and SV_UDSI_M1
François Grégoire
macfly is on a distinguished road
In UDF Manual 15.0 example 2.7.4.3 there is a line to retrieve the value of a scalar at previous time step:
phi_old = C_STORAGE_R(c,t,SV_UDSI_M1(i));
Couldn't we just do this instead:
phi_old = C_UDSI_M1(c,t,i);
macfly is offline   Reply With Quote
Old   May 20, 2015, 05:06
Default exactly my question
Franz Roman
franzdrs is on a distinguished road
I am wondering exactly the same. Did you found out if both options are equivalent?
Thanks
Franz
franzdrs is offline   Reply With Quote
Old   May 20, 2015, 07:32
François Grégoire
In the end I didn't use any previous time step macro. Instead I preferred to store variables in user defined memories (C_UDMI), an alternative way to compare with previous time step(s).
Old   May 20, 2015, 10:21
pakk will become famous soon enough
In mem.h, the following line is found:
#define C_UDSI_M1(c,t,i)C_STORAGE_R(c,t,SV_UDSI_M1(i))
This shows that
is the same as
So both options seem to be exactly the same. Until Fluent decides in a newer version to change the definition of C_UDSI_M1.
pakk is offline   Reply With Quote
Old   April 13, 2017, 05:59
saeed
saeed676 is on a distinguished road
Hi, I am beginner at using UDFs but I wonder maybe why not straight forward use this macro to calculate old value at previous timestep, suppose it's phi_old = temperature variable
phi_old = C_T_M1(c, t)
Thanks
saeed676 is offline   Reply With Quote
