UDF for Oscillating Membrane/Diaphragm of a Synthetic Jet
Old   December 8, 2014, 09:20
Default UDF for Oscillating Membrane/Diaphragm of a Synthetic Jet
cuan
cuan1029 is on a distinguished road
Greetings,
I tried to simulate synthetic jet and wanted to study the flow velocity and heat transfer of it.
However, I'm stuck with the UDF for the oscillating membrane.
I have go through one of the UDF tutorial,Using a UDF to Control the Dynamic Mesh of a Flexible Oscillating Membrane, which related to my topic.
For my case, I do not have the rotating butterfly but only the oscillating membrane which located at the bottom of the geometry
Attachment for my geometry
I tried to use the grid motion part in the UDF and do some minor modification according to my case, but I am not fully understand the UDF provided in the tutorial which causing me hard time.
The following is my UDF:
#include "udf.h"
#define  omega      1           /* rotational speed, rad/sec        */
#define  R          0.375        	/* radius of the arc, meters        */
DEFINE_GRID_MOTION(moving_arc, domain, dt, time, dtime)
  Thread *tf = DT_THREAD (dt);
  face_t f;
  Node *node_p;
  real alpha, theta, x, ymag, yfull, y;
  int n;
/* Set/activate the deforming flag on adjacent cell zone, which       */
/* means that the cells adjacent to the deforming wall will also be  */
/* deformed, in order to avoid skewness.                                   */
  SET_DEFORMING_THREAD_FLAG (THREAD_T0 (tf));
/* Compute the angles:                                               */
  alpha = omega * CURRENT_TIME;
  theta = 2.0 * alpha + 3.0 * M_PI / 2.0;
/* Loop over the deforming boundary zone's faces;                         */
/* inner loop loops over all nodes of a given face;                           */
/* Thus, since one node can belong to several faces, one must guard  */
/* against operating on a given node more than once:                       */
  begin_f_loop (f, tf)
      f_node_loop (f, tf, n)
          node_p = F_NODE (f, tf, n);
          /* Update the current node only if it has not been         */
		  /* previously visited:                                     */
          if (NODE_POS_NEED_UPDATE (node_p))
              /* Set flag to indicate that the current node's        */
			  /* position has been updated, so that it will not be   */
              /* updated during a future pass through the loop:      */
              NODE_POS_UPDATED (node_p);
			  x     = NODE_X (node_p);
			  ymag  = sqrt (R*R - x*x) + 0.03;
			  yfull = ymag - 0.1;
			  y     = yfull * sin(theta);
			  NODE_Y (node_p) = y;
  end_f_loop (f, tf);
Here is what I get after I previewed the dynamic motion in Fluent
In my case, do I have to use "theta" as written in the UDF above?
How to apply the UDF in tutorial for my case?
Thank you in advance for any help and advice.
cuan1029 is offline   Reply With Quote
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 07:43
Synthetic Jet Boundary Condition Karthikeyan D. Main CFD Forum 1 August 18, 2010 08:17
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 12:29
method to determine jet front Fred Main CFD Forum 0 February 8, 2007 14:15
IMPINGING JET ........... HELP!!!!!!!! Amir Omoumi Main CFD Forum 10 August 30, 1999 23:11
