UDF for particle velocity doesn't work !!
Old   November 17, 2021, 14:10
wasim.raza is on a distinguished road
I am using steady particle tracking in Fluent. I am trying to set the initial velocity of the particle same as the flow velocity in respective cells of the inlet surface,
I am using UDF, DEFINE_DPM_INJECTION_INIT(velocity_magnitude, I).
But, I am unable to check, whether the initial velocity has been applied to the particle or not. How can I check it?
Also, there is no effect on the result after using the UDF.
Thanks.
Originally Posted by pakk View Post
I would be interested in what happens with the following code:
#include "udf.h"
#include "dpm.h"
Particle *p;
cell_t c;
Thread *t;
loop(p,I->p_init)           /*Standard Fluent looping Macro to get particle streams in an inejction using unsteady particle tracking*/
c = P_CELL(p);              /*Get the cell that the particle is currently in*/
t = P_CELL_THREAD(p);       /*Get the thread that the particle is currently in*/
P_VEL(p)[0] =7;    /*Longitudinal velocity*/
P_VEL(p)[1] = 8;    /*Spanwise velocity*/
P_VEL(p)[2] = 9;    /*vertical velocity*/
Do you see velocities (0,0,0) or (7,8,9)?
wasim.raza is offline   Reply With Quote
Old   November 18, 2021, 09:21
pakk will become famous soon enough
Do you use the code that you quoted which still has problems, or do you include the solution that was given further below?
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   November 18, 2021, 20:36
I have used the code after including the solution as mentioned, by replacing loop(p,I->p_init) with loop(p,I->p). It compiled and it is available in the UDF Tab of particle injection.
I tried with high velocity in the UDF also , but the particle velocity is not changing in the output file sampled at the outlet.
Therefore, I want to check, whether the initial velocity has been applied to the particle or not. How can I do it?
Thanks
Old   November 19, 2021, 06:24
Plot one trajectory, showing the particle velocity.
UDF Unsteady velocity parabolic profile Rashad FLUENT 3 October 1, 2018 16:27
Simulation with UDF for species mass fraction and velocity profile virgy Fluent UDF and Scheme Programming 8 February 7, 2012 05:30
the udf has been hooked to the fluent successfully,but it does not work! hugeforest Fluent UDF and Scheme Programming 1 July 8, 2011 05:31
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
UDF velocity profile problem Steve FLUENT 0 January 18, 2005 13:11
