error: "Divergence detected in AMG solver: temperature" |
November 23, 2014, 09:50 |
milad
hi all, im working on a 3D transient project with UDF and imgetting this error,
Divergence detected in AMG solver: temperature and with some changes in afew time steps i get my continuty divergent may its bcoz of my UDF? why is that? |
December 1, 2014, 12:11 |
Rep Power: 16 |
Usually "Divergent dete..." error occurs due to the coarse or highly skewed mesh as well as large time step. You can check these two first and then post your UDF here to see if something is wrong with that.
cheers! |
December 3, 2014, 05:29 |
milad
tnx buddy
December 22, 2014, 04:14 |
Rishitosh Ranjan
Rep Power: 14 |
hello,
I m working on a 2D conduction problem with UDF and i m getting same error, "Divergence detected in AMG solver: temperature" just bcoz of my UDF!! why is that? Dis is my udf being used for boundary condition: #include "udf.h" #include "metric.h" #include "math.h" #define pie 3.14 /*pie value*/ #define Ttran 560 /*trasitional temperature*/ #define e 2.71828 /*value of e*/ #define A 0.70 /*absorptivity*/ #define P 600 /*peak power of laser*/ DEFINE_PROFILE(ht_flx_tp_srf, t, i) { real x[ND_ND]; real I, T, qc, hc; real em = 0.4; real Tamb = 300; real r = 200e-6; face_t f; begin_f_loop(f, t) { F_CENTROID(x, f, t); I = A*(P / (2 * pie*pow(r, 2)))*pow(e, -(pow(x[0], 2) / (2 * pow(r, 2)))); /*due to this line I m getting dis error*/ T = F_T(f, t); hc = (24.1e-4)*em*pow(T, 1.61); qc = hc*(T - Tamb); F_PROFILE(f, t, i) = I-qc; } end_f_loop(f, t) } plz take me out of this prblm... Thank you.. with reegards. |
December 22, 2014, 09:34 |
Rep Power: 16 |
I am not sure and but worth a shot...rename the "e" to something else or simply use the value itself instead of an argument.
December 22, 2014, 11:44 |
Rep Power: 13 |
Use monitors to check the values of your profile. In that of cases, there are not any errors in the code itself, but it passes unrealistic values to the solver of Fluent, which may take into a divergence of the solution.
In your example, imagine that you are giving to your case a wall heat flux of 10^20 W/m2. That will lead into an error for sure. Check the values and use monitors or messages in the TUI. And use M_PI instead of #define pie 3.14: it is poor programming. Cheers |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 10:21 |
Error: Divergence detected in AMG solver: x-momentum/ epsilon/ temperature | bubuchacha | FLUENT | 6 | February 26, 2013 04:30 |
" Divergence detected in AMG solver: temperature" | Suman | FLUENT | 4 | September 11, 2009 10:31 |
AMG solver _divergence detected | Shamoon | FLUENT | 6 | March 11, 2009 08:59 |
Error: divergence detected in AMG solver | Yash | FLUENT | 2 | December 2, 2008 11:12 |
