ajenecheng
Rep Power: 0 ![]() |
hello,
I want to calculate the velocity divergence of a specific cell as a source term, but there is access violation: Error: C:\PROGRA~1\ANSYSI~1\v145\fluent\fluent14.5.0\win6 4\2ddp\fl1450s.exe received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: #f can you give me some advice? the UDF is as follow: DEFINE_SOURCE(UDS_s_p2, c_UDS_s_p2,t_UDS_s_p2, ds_UDS_s_p2, eqn_UDS_s_p2) { real source_UDS_s_p2; Thread *mix_t_UDS_s_p2; Thread *t_UDS_s_liquid_p2; real NV_VEC(A_TOL),NV_VEC(VEC),NV_VEC(VEC0),NV_VEC(VEC1 ),NV_VEC(A); real div_V; Thread *tf; int f,n; cell_t c0, c1 = -1; Thread *t0, *t1 = NULL; source_UDS_s_p2=0.0; div_V=0; mix_t_UDS_s_p2=THREAD_SUPER_THREAD(t_UDS_s_p2); t_UDS_s_liquid_p2= THREAD_SUB_THREAD(mix_t_UDS_s_p2, 0); c_face_loop( c_UDS_s_p2, mix_t_UDS_s_p2,n) /*loop the faces of a specific cell*/ { f=C_FACE( c_UDS_s_p2,mix_t_UDS_s_p2,n); /* retrive the ID of face on liquid level */ tf=C_FACE_THREAD( c_UDS_s_p2,mix_t_UDS_s_p2,n); /* retrive the thread of face on liquid level */ c0 = F_C0(f,tf); t0 = F_C0_THREAD(f,tf); F_AREA(A,f,tf); if (BOUNDARY_FACE_THREAD_P(tf)) { NV_D(VEC,=,F_U(f,tf),F_V(f,tf),F_W(f,tf)); } else { c1 = F_C1(f,tf); t1 = F_C1_THREAD(f,tf); NV_D(VEC0,=,C_U(c0,t0),C_V(c0,t0),C_W(c0,t0)) ; NV_D(VEC1,=,C_U(c1,t1),C_V(c1,t1),C_W(c1,t1)); NV_VS_VS(VEC,=,VEC0,*,0.5,+,VEC1,*,0.5); } div_V+=NV_DOT(A,VEC); /* intergration of area dot velocity for all the faces in the cell */ } div_V/=C_VOLUME(c_UDS_s_p2,mix_t_UDS_s_p2); source_UDS_s_p2 =+ div_V; } ds_UDS_s_p2[eqn_UDS_s_p2]=0.0; return source_UDS_s_p2; } |
loop, source, velocity divergence |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
HELP! adding a mass source to VOF eqn. by UDF??? | ROOZBEH | FLUENT | 5 | December 3, 2016 17:53 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
