Problems regarding mass transfer UDF
Old   November 2, 2014, 04:09
Default Problems regarding mass transfer UDF
Gao Yifan
Yifan_G is on a distinguished road
Hi, I'm an undergraduate student using Fluent for my final year project. I have encountered some problems while using a mass transfer UDF in my simulation.
I found that every time I save and reload my case file, the mass transfer UDF becomes unhooked and I have to hook it again.
This become very troublesome when I try to send my case file to our high performance computer for calculation since the case file will definitely be reloaded and there won't be any mass transfer.
The information printed in the console shows that the UDF is successfully loaded. Also, I've tried different mass transfer UDFs and I'm pretty sure that it's not the UDF's problem.
Does anyone know how to solve this problem?
Thank you.
Yifan_G is offline   Reply With Quote
Old   November 2, 2014, 05:12
ad
adi.ptb is on a distinguished road
You should first compile your udf in high performance computer after that read your case file
adi.ptb is offline   Reply With Quote
Old   November 2, 2014, 05:17
Gao Yifan
Yea I have already complied my UDFs in the HPC for parallel computing.
Old   November 2, 2014, 05:39
ad
Did you use different versions of fluent in your pc and hpc?
Old   November 2, 2014, 13:14
Gao Yifan
I don't have access to ANSYS on my pc. Basically everything is done in the hpc. I have tried Fluent 14.0 and 15.0, both have the same problem.
Thanks.
Old   December 8, 2014, 10:38
G. S.
gerardosrez is on a distinguished road
I have the same trouble, I compile/load the UDF for mass transfer in Phases/Interactions.....
I write the case and data files then when I reopen magically the UDF has disappeared...
After I try to re-compile/load the UDF gives me an error...
Have you solved this my friend???
gerardosrez is offline   Reply With Quote
Old   December 8, 2014, 10:53
Cees Haringa
CeesH is on a distinguished road
Do you use a journal file on the HPC?
If so, put the compilation and hooking of the UDF inside the journal file. Otherwise the hooked UDF will still refer to the location it used to be when you set up the case and data - likely on your local machine - so even if the UDF is compiled at the cluster the path will not match and FLUENT won't find it.
CeesH is offline   Reply With Quote
Old   December 8, 2014, 11:11
G. S.
Dear Mr Ceesh,
I don't use HPC I use my own desktop...
Old   December 8, 2014, 11:21
Cees Haringa
what error do you get when recompiling?
hook, phase change, udf
Disappearing mass when using udf inlet profile divergence Fluent UDF and Scheme Programming 5 January 2, 2021 15:56
using define mass transfer udf for cavitation Komon Fluent UDF and Scheme Programming 14 June 21, 2016 03:50
udf for mass transfer hane Fluent UDF and Scheme Programming 1 April 19, 2014 14:40
Mass transfer UDF expecting void return Quinos Fluent UDF and Scheme Programming 0 January 8, 2014 19:36
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 12:29
