make the inlet volume fraction equal to the outlet - udf syntax error
Old   October 23, 2014, 15:46
Default make the inlet volume fraction equal to the outlet - udf syntax error
kong
kongl1986 is on a distinguished road
Hello everyone,
I am new to writing udf.
Currently, I would like to write a udf file to make the inlet volume fraction equal to the outlet.
The code is following.
however when I compiled it, the fluent shows:
Copied C:\Users\LKong\Documents ank\mt\1nz/C:\Users\LKong\Documents ank\mt\1nz\ioc.c to libudf\src
udf_names.c file in 2d_host is upto date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v145\fluent"\fluent14.5.0\sr c\makefile_nt.udf "libudf\win64\2d_host\makefile" ")
1 file(s) copied.
(chdir "libudf")()
(chdir "win64\2d_host")()
# Generating ud_io1.h
ioc.c
..\..\src\ioc.c(21) : error C2143: syntax error : missing ';' before '{'
..\..\src\ioc.c(24) : error C2059: syntax error : '}'
udf_names.c file in 2d_node is upto date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v145\fluent"\fluent14.5.0\sr c\makefile_nt.udf "libudf\win64\2d_node\makefile" ")
1 file(s) copied.
(chdir "libudf")()
(chdir "win64\2d_node")()
ioc.c
Done.
I did not found I miss the ; before the { or }.
could some one help me with this, thank you very much
#include "udf.h"
DEFINE_ADJUST(outletvf,d)
face_t face;
real vf=0.0;
real tarea=0.0;
real avevf=0.0;
real A[ND_ND];
int ID1=14;
Thread *outlet_thread=Lookup_Thread(d,ID1);
int ID2=13;
Thread *inlet_thread=Lookup_Thread(d,ID2);
begin_f_loop(face,outlet_thread)
tarea +=F_AREA(A,face,outlet_thread);
vf +=F_AREA(A,face,outlet_thread)*F_VOF(face,outlet_t hread);
end_f_loop(face,oulet_thread)
avevf=vf/tarea;
beginf_f_loop(face,inlet_thread)
F_UDMI(face,inlet_thread,1)=avevf;
end_f_loop(face,inlet_thread)
DEFINE_PROFILE(inletvf,t,i)
face_t f;
begin_f_loop(f,t)
F_PROFILE(f,t,i)=avevf;
end_f_loop(f,t)
kongl1986 is offline   Reply With Quote
Old   October 27, 2014, 06:52
pakk will become famous soon enough
First of all: there seems to be a space in your folder name. ("Documents ank") I don't see it giving any problems now, but it can give you problems later, and it is safer to do it without space, for example with an underscroe. ("Documents_ank")
Secondly: you wrote "beginf_f_loop" where you meant "begin_f_loop".
pakk is offline   Reply With Quote
Old   October 27, 2014, 14:02
kong
thank you.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 06:34
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
