reverse flow at the outlet
Old   October 15, 2014, 11:54
Default reverse flow at the outlet
Khalid Ansari
khalidansari4u is on a distinguished road
hello,
i m working on flow past a rotationally oscillating cylinder.
and i m using udf and dynamic mesh for it. so when i m using udf file and running the calculation. it is constantly giving me reverse flow at the outlet.
and the solution doesnt converge. pls help me experts.
plsss.
i extended the outlet far from the cylinder. used 2nd order upwind momentum equation.
khalidansari4u is offline   Reply With Quote
Old   October 18, 2014, 01:53
samurai_01 is on a distinguished road
Which boundary condition did you use. My guess is you have used Pressure outlet BC (given your problem is at low RE, if its a compressible flow problem, then its a different game altogether). Try using outflow instead.
samurai_01 is offline   Reply With Quote
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
Temperature at a velocity/mass flow outlet saisanthoshm88 CFX 1 July 8, 2014 19:35
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 13:30
CAN'T CONVERGE WITH REVERSE FLOW AT OUTLET! XIAOYI LI FLUENT 11 September 14, 2012 17:43
CFDesign V11 -- Reverse flow at outlet maruthiv Autodesk Simulation CFD 1 June 17, 2011 10:38
