Accessing output parameter value in scheme
Old   October 11, 2014, 14:18
Default Accessing output parameter value in scheme
nnvoro is on a distinguished road
Dear all,
Does anybody know if there is a way to access output parameter value in scheme file?
I create UDM in UDF which is defined for each cell of the domain. I need to use the maximum (on the domain) value of the UDM in my scheme file. For that I create output parameter in my journal file using command:
define/parameters/o-p/create/surface-integral "parameter-1" facet-max udm-2 soutlet1_3_1 ()
I want to use the value of the parameter-1 (or maximum value of the udm-2) in my scheme. For that I tried to create scheme variable having the value of the parameter-1 using command:
(rp-var-define 'press_diff (rpgetvar 'parameter-1) 'double #f)
but it didn't work. I get the message:
Error: rp-var-value: undefined variable
Error-Object: parameter-1
nnvoro
nnvoro is offline   Reply With Quote
Old   October 11, 2014, 15:53
I think I might try to do that in a slightly different way which looks more complicated to me.
I will calculate average value of the udm (in my particular case max and average value are the same) in udf:
real a=0.0;
int c_count = 0;
thread_loop_c(ct,d)
begin_c_loop(c,ct)
a+=C_UDMI(c,ct,2);
c_count++;
end_c_loop(c,ct)
a = a/c_count;
And then export the value to the fluent in the udf using command:
RP_Set_Real("press_diff",a);
In the journal file I should have the command which creates and initializes variable "press_diff", this command should be executed before executing udf:
(if (not (rp-var-object 'press_diff))(rp-var-define 'press_diff 0 'double #f))
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 11 November 6, 2017 22:20
Use of upwind scheme for interpolation of u/v quarkz Main CFD Forum 6 August 30, 2011 05:10
Questions about data output aki_yafuji OpenFOAM Running, Solving & CFD 3 September 9, 2010 02:59
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 13:30
[Other] Output Format of MetaMesh t42 OpenFOAM Meshing & Mesh Conversion 0 August 3, 2007 05:28
