Help with Grid Motion UDF
Old   October 4, 2014, 23:05
Default Help with Grid Motion UDF
Exodiah is on a distinguished road
Hi, I would like to ask if it is possible to define a grid motion for a surface, and a different and separate grid motion for the adjoining cell domain?
That means, the surface will be deforming according to a function, and the cell domain deforming to another similar function. I have tried using two separate udfs to define the surface and corresponding cell domain, but the mesh updating at the start of the time step fails.
Should I only define a grid motion for the cell? But if so, what should be the appropriate setting for the surface in the dynamic mesh tab?
Appreciate any advice or comments.
Exodiah is offline   Reply With Quote
CG Motion UDF Problem leoarmas Fluent UDF and Scheme Programming 17 February 14, 2023 09:59
UDF problem: incorrect grid motion Fil FLUENT 5 December 19, 2020 10:16
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Sinusoidal motion udf urmazda Fluent UDF and Scheme Programming 6 July 30, 2010 12:44
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 15:17
