Need Clarification regarding Volumetric Reactions in Fluent
Old   October 3, 2014, 11:59
Default Need Clarification regarding Volumetric Reactions in Fluent
Kashif Rashid
Kashif Rashid is on a distinguished road
I have written UDF in C, using fluent macro, “DEFINE_ADJUST”, for internal steam reforming (file attached). Reforming reactions have to take place inside porous anode electrode of Fuel Cell. Pre-reformed fuel mixture is used which consist of (CH4, H2, H2O, CO, CO2). The source terms are hooked in "Cell Zone Conditions" of fluent. UDMI, memories in Fluent are also allocated to store data for above terms (see code file). Initialization and msr_adj are also hooked, segregated solver is used. Energy, species models are tern on.
After doing all these things and running simulation, reactions are not taking place; there is no change in concentration of species at inlet and outlet.
However, when I selected Volumetric Reactions in the Fluent, second Laminar Finite-Rate, third the values of Pre-Exponentional Factors and Activation Energies are adjusted to my own required Arrhenius Rate, and fourth, stoichiometric coefficients are also set according to reforming and shift reactions.
After making above mentioned changes, plus using UDF, reactions are taking place. Because of these issues, I want to know/clarify following things:-
1. Is it necessary or mandatory to activate the Volumetric Reactions within the Fluent in the presence of UDF ??
2. Will this activation of Volumetric Reactions duplicate the calculations. Because i want to incorporate my own rate modeling through UDF whereas, Fluent is using Arrhenius Rate model. Which model is executed during simulation ?
3.Can i modify fluent Arrhenius rate model and other setting according to my own requirements ???
Kashif Rashid is offline   Reply With Quote
Linux Fluent HPC parallel system check failed saad3000 FLUENT 1 January 8, 2021 04:34
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
FLUENT Reactions problem K. Alageel FLUENT 2 February 17, 2013 12:40
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 12:55
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 03:44
