UDF compiling error
Old   September 28, 2014, 03:36
Question UDF compiling error
wzhang11 is on a distinguished road
Hi, i using the uni computer to follow the fluent tutorial 15 dynamic mesh. however, when i load the valve.c after build. the error shows the UDF library you are trying to load(libudf) is not compiled for 2d on the current platform (win64), the system cannot find the file specified.
i read some solutions for this, but as using the uni computer,i am limited to install or reinstall the fluent.
what should i do to fix this problem?
BTW, i am trying to apply a motion on a cylinder under the water, is there any other ways instead of UDF method to make it?
Cheers
Jason
wzhang11 is offline   Reply With Quote
Old   September 29, 2014, 06:08
pakk will become famous soon enough
It looks like your valve.c did not compile. That is what the message says.
pakk is offline   Reply With Quote
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 21:16
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
