DPM, access particle data - number of tries
Old   September 9, 2014, 10:07
Default DPM, access particle data - number of tries
wsaac is on a distinguished road
Hello everyone
I am able to access all particles in a domain if the number of tries is 1, but if I set this number to a higher values the number of Tracked_particle's increases (given a uniform distribution e.g.). Is it possible to also receive the data from these additional particles?
Using the standard loops (over the injections or begin_particle_cell_loop), I am still only able to access the ''original'' particles. If i try to access it by using the *next pointer in the Particle struct it doesn't work. There is no *next pointer in the Tracked_particle struct.
Is there any way to access the Tracked_particle data?
wsaac is offline   Reply With Quote
Old   July 31, 2018, 03:40
hxw
jackstraw is on a distinguished road
now,I are faced with the same problem. Did you solve it? If yes, please share your works. Thanks a lot!
jackstraw is offline   Reply With Quote
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 13:01
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 09:14
Dpm model, setting particle number wagnerqb FLUENT 7 March 23, 2013 22:06
How to put melting Point data of inert particle in DPM model subhankar_bhandari Main CFD Forum 0 July 26, 2010 08:28
