Adaptive time stepping
Old   August 28, 2014, 07:56
Default Adaptive time stepping
Thomas Green
.Thomas. is on a distinguished road
I post again here because maybe the discussion in which I posted was closed.
Dear All,
I have the same problem of DIVERGENCE DETECTED IN AMG SOLVER: y-momentum.
I am simulating a constant flow profile but I would like to analyze it in transient mode.
My mass flow inlet is of 0.000001 kg/s, I thought that using an adaptive time step that change from 0.001 for the first second to something bigger for the rest of the simulation (for instance 10 seconds) because the fluid flow will be developed.
Solution Method (in order): PISO (Skewness Correction & Neighbor Correction = 1), Least Squares Cell Based, Second Order, Second Order Upwind, First Order Implicit.
Run Calculation: Adaptive Time Stepping Method (deltat); Time Step Size (s)=0.001 (because I have to select the initial time step); Number of Time Step=1000, Max Iterations/Time Step=200.
My code for the adaptive time stepping is:
#include "udf.h"
DEFINE_DELTAT(deltat,d){
real time_step;
real tx=CURRENT_TIME;
if ( tx<=1 ) {
time_step=0.001;
else{
time_step=10;
return time_step;
I don`t get very well what is wrong in what I am doing, anybody has suggestions?
Thank you so much.
Thomas
.Thomas. is offline   Reply With Quote
Old   August 28, 2014, 09:52
pakk will become famous soon enough
If your time is below 1 second, nothing is returned.
#include "udf.h"
real time_step;
if ( tx<=1 ) {
  time_step=0.001;
} else {
  time_step=10;
return time_step;
If you do this, the time_step will always be returned. (I don't know if this will solve your problem.)
pakk is offline   Reply With Quote
Old   August 28, 2014, 11:18
Thomas Green
Thank you so much! It works perfectly
time step size, transient analysis, transient convergence, udf and programming
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
number of iterations per time step chouki FLUENT 1 August 13, 2013 01:11
adaptive time stepping new Fluent user FLUENT 0 May 24, 2007 08:53
Adaptive Time Stepping: extrange behavior! Freeman FLUENT 0 December 2, 2005 14:31
