UDF for volume fraction
Like Tree12Likes
Old   March 1, 2016, 09:19
Hossein
hossein65 is on a distinguished road
I compiled your code, but I am trying to use it for DEFINE_PROPERTY. For the error you get, I put mixture_domain=Get_Domain(1). It compiles and runs well
Hossein Amini
PhD student in Biochemical Engineering; Computational Science and Engineering department;
North Carolina Agricultural and Technical State University
hossein65 is offline   Reply With Quote
Old   March 1, 2016, 09:37
Hossein
Originally Posted by sirpolar View Post
Dear sun the other friends
I have written the UDF as follows, when I interpreted it to the fluent it is ok
But when I want to run (after initialization) the fluent gives this error:
FLUENT received fatal signal (ACCESS_VIOLATION)
I was wondering if you know what is wrong with it?
#include "udf.h"
DEFINE_ADJUST(viscouse_function, d)
real visc;
cell_t cell;
Thread **pt;
Thread *cell_threads;
Domain *mixture_domain;
mp_thread_loop_c(cell_threads, mixture_domain, pt)
begin_c_loop(cell,pt[1])
visc = 1- ((0.95-(C_VOF(cell,pt[1])))-0.25);
end_c_loop(cell,pt[1])
I put mixture_domain=Get_Domain(1) to initialize the domain, and it perfectly compiles and runs with DEFINE_PROPERTY macro that I am using. But the problem is that I get ridiculous constant VOF values which do not match the actual VOF values for my model. I have a two phase Eulerian mixture (Water+Carbon (as fluid)) and cannot get the real carbon VOF values. The funny thing is that when I comment out the line containing the visc function (1-((0.95-(C_VOF(cell,pt[1])))-0.25)) and put a constant number (say 1.0), I get the water VOF !! which doesn't make sense because I am removing the C_VOF (cell,pt[1]) variable. I mean when I say visc=1.0, I get the water VOF. However, I cannot define any functions based on these values unless, and only can multiply the returned value by some numbers and get the result. When I do subtract, add or something else, it doesn't work. Any ideas?
Hossein Amini
Old   October 9, 2017, 08:23
Default The same problem !
  #23
ali
ebtedaei is on a distinguished road
Dear Ebrahim,
I have a same problem like your case and just my viscosity function is different. Did you solve your UDF's problem?
I would be appreciated if you could help me on this.
Thanks in advance,
Ali
ebtedaei is offline   Reply With Quote
Old   October 9, 2017, 08:25
ali
Dear Ebrahim,
Thanks in advance,
Ali
Old   October 9, 2017, 08:56
  #25
ali
Dear Ebrahim,
I have a same problem with you problem. Just my viscosity function is different.
Did you solve the UDF's problem(viscous function vs volume of fraction)?
Thanks in advance,
Ali
#include "udf.h"
real visc;
cell_t cell;
Thread **pt;
Old   October 9, 2017, 09:23
pakk will become famous soon enough
The solution was already given by Hossein Amini, just above your message.
If you are interested in what was the reason for the error message: the variable "mixture_domain" is defined, but never given a value. You ask the computer to say something about a mixture domain, but you don't tell him which mixture domain (even though you probably only have one), so Fluent is confused.
pakk is offline   Reply With Quote
Old   October 9, 2017, 10:29
ali
What is [**pt] in 6 line and[*] in 7 , 8 lines?
Thanks,
Ali
#include "udf.h"
real visc;
cell_t cell;
Thread **pt;
Old   October 9, 2017, 10:50
The star indicates that the variable is a pointer.
Old   October 23, 2017, 11:21
Default Add UDF in Fluent's materials section?
  #29
ali
Hi All,
I wrote UDF code in Fluent and I added it instead of the constant amount of water viscosity, but I have not answered so far! Should special settings be made?
Thanks,
Ali
Old   October 24, 2017, 05:41
I don't understand what you are asking.
Old   October 24, 2017, 16:02
ali
I want to write a UDF for Viscosity function of mixture phase vs. Volume of fraction of second phase.
Old   October 24, 2017, 16:05
ali
I have a twophase flow :
Water and a other fluid phase
Old   October 25, 2017, 03:38
And you already wrote a UDF or not?
What is your problem? Do you not know how to write it? Or do you get errors? Or do you get unexpected results?
If you want help, don't let us guess at what you are doing...
Old   October 25, 2017, 05:26
Sun
Sun's Avatar
Sun is on a distinguished road
Hi ali, as pakk said your question is bit unclear.
Please share your UDF, or maybe the function you are trying to code for the viscosity. In case you are getting unexpected results, please share the results and tell us why you think they are wrong. So, everyone will have a better understanding of the problem.
cheers
Sun is offline   Reply With Quote
Old   November 4, 2017, 01:29
Default UDF for viscosity
  #35
ali
Thank you for your reply.
I use a mix model that the water and the other phase (X) are mixed, which phase water and phase X have individual properties (density and viscosity).
In the Inlet Boundary Condition, the phase X with a certain amount of volume of fraction (alphaX) is mixed with the water phase However, in different points of the domain and at different times, the volume of fraction of the X phase changes, and subsequently the viscosity of the mixed phase (m) also changes according to the formula:
Viscosity (m) = 3.8 * viscosity (water) * (1-(alphaX/0.62))^(-1.55)
Where, the viscosity function of the mixture phase (m) varies according to the volume of fraction (alpha X) of the phase X, and also the μc is the constant value of the viscosity of water.
A very similar example to my problem that I found on the cfd-online site is as follows:
It is important that based on a study on related articles, I have to replace the UDF file on the constant amount of water viscosity in the Materials substitute of fluent to vary the viscosity of the mix phase at different points and at different times in the domain.
Of course, I have already written three UDF codes, but I have not responded to any of these.
Thank you in advance for your commenting on any of these fallowing codes:
File Type: c Viscosity_1.c (357 Bytes, 15 views)
File Type: c Viscosity_2.c (564 Bytes, 9 views)
File Type: c Viscosity_3.c (376 Bytes, 9 views)
Old   November 4, 2017, 06:29
Sun
Sun's Avatar
Maybe you can use both
DEFINE_ADJUST
and
DEFINE_PROPERTY
. Here is an example, you might need to modify it based on your needs:
DEFINE_PROPERTY(viscosity_mix,c,t)
	real viscosity;
    viscosity = C_UDMI(c,t,1);
    return viscosity;
DEFINE_ADJUST(my_adjust,mixture_domain)
	Thread *t;
	cell_t c;
	Thread **pt;
	real mu_water = 0.00103;
	mp_thread_loop_c(t,mixture_domain,pt)
	   begin_c_loop(c,t)
		C_UDMI(c,t,1) = 3.8*mu_water*(pow((1.0 - C_VOF(c,pt[1])/0.62), -1.55));
        end_c_loop(c,t)
Please remember to define a user define memory before compiling, because the values are stored in an UDM.
hope it helps
cheers!
Old   November 5, 2017, 10:17
ali
Thanks for your reply.
What do you mean by last statement:
"Please remember to define a user define memory before compiling, because the values are stored in an UDM."
How can I define a user define memory before compiling?
I isn't professional in writing UDF!!!
Old   November 5, 2017, 11:16
ali
What numbers do I enter in this window?
Old   November 6, 2017, 05:37
If you want to have one User Defined Memory, change the first zero (0) into a one (1).
Old   November 6, 2017, 07:39
ali
Originally Posted by Sun View Post
DEFINE_ADJUST
and
DEFINE_PROPERTY
	real viscosity;
    return viscosity;
	Thread *t;
	cell_t c;
	Thread **pt;
	   begin_c_loop(c,t)
        end_c_loop(c,t)
hope it helps
cheers!
As you see, In my case two fluids are mixed together: water and another fluid called ferrosilicon (Other than Air).
In udf code that you wrote, how do I understand the software that the volume fraction (vof) is related to the ferrosilicon fluid?
udf: volume fraction gradient in eulerian model jwwang FLUENT 22 April 15, 2015 07:27
Conversion of mass fraction to mole fraction in FLUENT prince_pahariaa FLUENT 0 August 26, 2014 09:08
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 11:46
UDF for Species mass fraction daniel FLUENT 3 June 22, 2005 09:40
Species Mass Fraction inside UDF using PDF? Daniel Schneider FLUENT 0 September 20, 2000 07:34
