Manipulating UDMs
Old   August 19, 2014, 11:29
Default Manipulating UDMs
jose casella
josecasella is on a distinguished road
I'm writing up a UDF which runs with the dpm. Basically I need to count and store in UDMs the number of particles hitting the outlet of a cyclone. The approach is as follows:
1) The first UDM-0 counts the total number of particles regardless its injection-ID
2) UDMs from 1-9 counts the particles hitting the outlet per each individual injection-ID.
3) Using Define_at_end Macro I need to count the number of faces at the inlet in order to store (UDM-10) the total number of particles injected per each injection defined
4) Using Define_at_end macro need to divide each UDMs from 0-9 (particles hitting the outlet per injection ID) by the UDM-10 (total number of faces at the inlet).
The problem I have at the moment are:
1) I am using the default "injection-0" name in fluent and writing the following in the UDFs to count the particles from injection 0:
IF(P_INJ_ID(P_INJECTION(P))==0
C_UDMI(F_C0(F,T),THREAD_T-(T),0)+=1;
By comparing with the report given by the sampling in fluent I realized the UDF counts particles based on the end_number of the following:
injection-0:5 (instead of increasing the UDM for injection-0, increases the one for injection 5)
2) UDM-10 (faces at the inlet) after the begin_c_loop get a value of 1.
DEFINE_EXECUTE_AT_END(efficiency_per_particle)
Domain *d = Get_Domain(1);
cell_t c;
Thread *t;
int i,j;
int ID=2;
t = Lookup_Thread(d, ID);
begin_c_loop(c,t)
C_UDMI(c,t,10) +=1;
end_c_loop(c,t);
begin_c_loop(c,t)
for(i=1;i<10;i++)
j=i+10;
C_UDMI(c,t,j)=C_UDMI(c,t,i)/C_UDMI(c,t,10);
end_c_loop(c,t);
I wonder how can I do to identify the correct ID of the injection and also how can I divide properly the values of the UDMs that are stored at the outlet face by the value of UDM-10 which is obtained at the inlet.
Many thanks!
Jose
josecasella is offline   Reply With Quote
user defined memory (UDMs) Musa FLUENT 1 October 16, 2012 22:12
[ICEM] Problem with graphics while manipulating model (frozen for some seconds) Freeman ANSYS Meshing & Geometry 4 October 17, 2009 15:35
Manipulating Tolerances in "eoslide" command sdwijeya STAR-CD 0 September 30, 2009 18:59
Solve->Initialize before using UDMs? Prashanth FLUENT 0 March 2, 2009 02:46
Manipulating the advection term of the UDS Ameya Durve FLUENT 0 February 24, 2009 14:52
