help with dev c++ source code and fluent library issue
Old   August 8, 2014, 11:51
Default help with dev c++ source code and fluent library issue
Ali
alee1293 is on a distinguished road
i try to write a udf for transient temperature profile but when i write the code in dev c++ as .c source file, program gave errors for not reaching header files. i updated the c libraries in the dev c++ directory but this time code gave thousands of syntax errors within the udf.h file. i copied header files from the fluent database but i can not create udf file...
anyone can help me please it is urgent!!!
alee1293 is offline   Reply With Quote
Old   August 8, 2014, 12:06
Cees Haringa
CeesH is on a distinguished road
Can you share the code?
A lot of syntax errors likely means you forgot a ; or bracket somewhere, and the error propagates through the rest of the code
CeesH is offline   Reply With Quote
Old   August 8, 2014, 12:09
Ali
i understand but these are not the errors causing from my code, these errors comes from the included ''udf.h'' file in the library i don't know how to solve it and i don't know it is because the fluent database or not..
Old   August 8, 2014, 12:30
Ali
#include <udf.h>
DEFINE_PROFILE (x_velocity,thread,index)
real x[ND_ND];
real y;
face_t f;
begin_f_loop(f,thread)
F_CENTROID(x,f,thread);
y=[x];
F_PROFILE(f,thread,index)=20.-y*y/(.0745*.0745)*20.;
end_f_loop(f,thread)
for starting i try to form a simple code but compiler giving errors at include line as i mentioned above
How to call FORTRAN files as UDF? Ehsan-F Fluent UDF and Scheme Programming 6 September 11, 2012 12:03
Fluent Source Code Crystal Main CFD Forum 5 March 3, 2010 21:34
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 14, 2000 00:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
Source code to read Fluent UNS cas and dat files Boyd Pukalo FLUENT 0 November 26, 1999 22:19
