Very simple question
Old   August 5, 2014, 09:42
Default Very simple question
stef_pasc is on a distinguished road
Hi everybody, I'm trying to validate my code and I discovered that there is a problem in some loops. In particular, I found out that if I make 2 identic loops over cells, I do not obtain the same results. So, in a very simple way, I obtain that the following code gives:
number of cells from loop 1 = 1041
number of cells from loop 2 = 847
The problem is that 2 loops are identical and that I have a mesh of 2024 cells.
DEFINE_ADJUST(adjust_gradient, d)
Thread *t;
cell_t c;
int i;
i=0;
thread_loop_c (t,d)
begin_c_loop (c,t)
i+=1;
printf("boucle cell %d \n", i);
end_c_loop (c,t)
DEFINE_ADJUST(adjust_grad, d)
Thread *t;
cell_t c;
int k;
k=0;
thread_loop_c (t,d)
begin_c_loop (c,t)
k+=1;
printf("boucle cell2 %d \n", k);
end_c_loop(c,t)
Can anybody help me?
Stefano
stef_pasc is offline   Reply With Quote
Old   August 5, 2014, 21:49
blackmask will become famous soon enough
You should have got thousands of lines of output. Try to print the result at the end of loop:
Thread *t;
cell_t c;
int i;
i=0;
thread_loop_c (t,d)
				begin_c_loop (c,t)
					i+=1;
				end_c_loop (c,t)
Did you run FLUENT in serial or parallel mode?
blackmask is offline   Reply With Quote
Old   August 6, 2014, 03:55
Thank you blackman!! Indeed I have thousands of lines but I did intentionally for looking all loops!
I run in parallel mode cause I compile it on Windows. I do not really understand how a so simple action could be wrong!!!
Old   August 20, 2014, 05:21
upeksa is on a distinguished road
In not that simple actually, you have to take into account parallel considerations.
Note that you will find very different result according to the number of partitions of your case.
Thread *t;
cell_t c;
int i;
i=0;
thread_loop_c (t,d)
begin_c_loop (c,t)
i+=1;
end_c_loop (c,t)
i=PRF_GISUM1(i);
I think it will work that way, I didn't test it. For further information, read that chapter of your manual.
upeksa is offline   Reply With Quote
[blockMesh] mergePatchPairs(); simple question seav OpenFOAM Meshing & Mesh Conversion 0 May 2, 2014 09:57
Simple Outlet Question m.nichols19 OpenFOAM 3 June 25, 2010 02:44
Simple Question Regarding Symmetry Planes Atella CFX 3 April 11, 2010 07:44
Simple Question Regarding Symmetry Planes Atella Main CFD Forum 0 April 9, 2010 11:58
Question of Anil Date's SIMPLE method universez Main CFD Forum 0 November 18, 2009 21:12
