UDF running three times each iteration
Old   August 4, 2014, 10:24
Unhappy UDF running three times each iteration
Anonymous
marauder is on a distinguished road
When I'm interpreting the UDF it is doing it three times like this
cpp -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/multiport/src" -I. -DUDF
ONFIG_H="<udfconfig-host.h>" "D:\cfd runs\new\usf\udf_trial1.c"
ONFIG_H="<C:/Users/623465~1.DSB/AppData/Local/Temp/udfconfig-node0.h>" "C:/Users//AppData/Local/Temp/udf_trial1.c.0.c"
ONFIG_H="<C:/Users/623465~1.DSB/AppData/Local/Temp/udfconfig-node1.h>" "C:/Users/AppData/Local/Temp/udf_trial1.c.1.c"
When I make a run the udf is getting executed three times per iteration giving some garbage values in two of those, which is affecting my run what is the reason for this??
marauder is offline   Reply With Quote
Old   August 4, 2014, 10:37
Anonymous
Sorry! Got it! Switched on parallel when my code was written for serial computing!
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
ITERATION in udf slek Main CFD Forum 0 July 8, 2010 22:09
A Loop problem when running UDF in the batch mode Jun Geng FLUENT 3 July 16, 2008 09:34
compiling my UDF Seyed Farid Hosseinizadeh FLUENT 22 February 14, 2006 11:19
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
