UDF diffusivity: problem with contour
Old   August 4, 2014, 04:28
Default UDF diffusivity: problem with contour
Lilly is on a distinguished road
Dear all,
I didn't get any reply in the Fluent forum, but maybe somebody in the UDF forum has an idea about this problem:
I have got a problem with the contour of the result of the mass diffusivity of my species, which I calculated using the strain rate. I also use the strain rate to calculate the viscosity of my fluid via a udf and have no problems showing this for several planes using "contour plot".
For any reason, if I load a data file and try to plot the mass diffusivity in a plane it only shows me a constant value (for each plane the same), which ist the constant part of my diffusivity equation (see pic), but not the part which ist calculated using the strain rate. But if I record "monitor data" in the single planes, a value changing with the strain-rate can be seen.
If I make fluent calculate one more iteration, I receive a correct contour plot including the "strain-rate-part" (see pic). However, if I save this case&data now and reopen it, the proper contour-plot is gone again and only the constant value is shown.
Does anybody have any idea how to solve this problem?
I am really thankful for any idea, since I don't have a clue!
Lilly
Lilly is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Kinematic Diffusivity - Problem with additional variable clau90 CFX 3 May 14, 2014 10:54
Contour Problem in Interface Boundary inra FLUENT 1 May 29, 2010 06:22
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 11:22
