Set UDS on wall...
Old   July 24, 2014, 11:03
Default Set UDS on wall...
Phoevos
fivos is on a distinguished road
Hi to everyone,
I am trying to calculate the material derivative of a quantity in the near wall vicinity (i.e. at the 1st cell from the wall) and, for post processing reasons, I want to plot it on the wall surface. The simulation is mixture multiphase, with 2 phases.
So I built the following UDF:
 DEFINE_ADJUST(calculate_dadt,d)
 real time_step, dvofdt_e, dvofdt_m;
 int n;
 Thread *t, *tf;
 cell_t c;
 face_t f;
 d = Get_Domain(1); /* mixture domain if multiphase */
 time_step = CURRENT_TIMESTEP;
 thread_loop_c (t,d)
 begin_c_loop(c,t)
 C_UDSI(c,t,2) = 0;
 dvofdt_e = (C_UDSI(c,t,0)-C_UDSI_M1(c,t,0))/time_step;
 dvofdt_m = dvofdt_e
           +C_U(c,t)*C_UDSI_G(c,t,0)[0]
           +C_V(c,t)*C_UDSI_G(c,t,0)[1]
           +C_W(c,t)*C_UDSI_G(c,t,0)[2];
 C_UDSI(c,t,2) = dvofdt_m;
/* set UDS on the wall */
 c_face_loop(c,t,n)
 tf = C_FACE_THREAD(c,t,n);
 f = C_FACE(c,t,n);
 if (THREAD_ID(tf) == 8)
 F_UDSI(f,tf,2) = C_UDSI(f,tf,2);
 end_c_loop(c,t)
As you can see in the UDF, I calculate the material derivative of the UDS with index 0 and store it to a new UDS with index 2. Then, I try to put the values of the UDS 2 on the faces of a specific boundary, with ID 8. The problem is that even if I compile successfully my UDS, load it, run fluent without any problem, the UDS returns a zero value on the wall, while the UDS value at the adjacent cell is different from zero; the aforementioned representation is done by nodal and cell values - nodal values on the boundary are zero, whereas cell values are different from zero..
I have to mention that, since I do not want to solve for the UDS, but only to calculate gradients, I exclude it from Solution Controls -> Equations, however I hook the above UDF as a DEFINE_adjust UDF.
Does anyone have any idea how can I instruct Fluent to copy the cell values of the desired UDS on selected wall boundaries?
Thanks in advance..
fivos is offline   Reply With Quote
Old   July 24, 2014, 22:48
blackmask will become famous soon enough
First of all,
is equivalent to "x = x". It seems that you meant
F_UDSI(f, tf, 2) = C_UDSI(c, t, 2);
It could be more efficient if you use a combination of
Lookup_Thread, F_C0, THREAD_T0
outside of cell loop instead of doing face loop inside of cell loop.
blackmask is offline   Reply With Quote
Old   July 25, 2014, 06:57
Phoevos
Blackmask you are absolutely right!
I was confused with the thread/cell/face indexes that's way it did not work. Now it works as it should!
I will think about implementing it the way you proposed, instead of looping all cells...
Thanks a lot.
correction of Grub after installing Windows XP and 8 immortality Lounge 20 January 5, 2014 18:41
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 20:51
UDS flux through wall and interior face. shuqin FLUENT 2 July 29, 2006 04:54
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
