July 23, 2014, 10:24 |
HEEELP!! Laplacian temperature
Rep Power: 12 |
Hi everyone!!
I'm trying to calculate the laplacian of temperature field in order to introduce it into the source terme of energy equation. Here there is a simplification of my C code. DEFINE_ADJUST(adjust_gradient, domain) { Thread *t; cell_t c; if (! Data_Valid_P()) return; thread_loop_c (t,domain) { begin_c_loop (c,t) { C_UDSI(c,t,0)=C_T_RG(c,t)[0]; C_UDSI(c,t,1)=C_T_RG(c,t)[1]; C_UDSI(c,t,2)=C_T_RG(c,t)[2]; } end_c_loop (c,t) } } DEFINE_SOURCE(energy_source,c,t,ds,eqn) { real source; source=20*C_UDSI(c,t,0); C_UDMI(c,t,0)=C_UDSI(c,t,0); C_UDMI(c,t,1)=source; C_UDMI(c,t,2)=C_UDSI_G(c,t,0)[0]; /*some calculus for testing the data*/ C_UDMI(c,t,3)=1/C_UDSI_G(c,t,0)[0]; C_UDMI(c,t,4)=100*C_UDSI_G(c,t,0)[0]; ds[eqn]=0; return source; } The operations I make are: Add User Scalars and memory Inactivate UDS equations Tape solver/set/expert---> yes for "keep temporary solver memory ...." Launch the computation SO I have 2 principal problems: Sometimes, I receive a "segmentation fault" error message: this is due to the lines C_UDSI(c,t,0)=C_T_G(c,t)[0]; C_UDSI(c,t,1)=C_T_G(c,t)[1]; C_UDSI(c,t,2)=C_T_G(c,t)[2]; If I use C_T(c,t), there's no more problems...whyyy??; In this case, if I plot "Reconstruction dT/dx", Scalar 0 and Memory 0, they should coincide but there some little differences. Is there someone who can help me, pleeease??? Thank you guys!!! Stefano |
July 24, 2014, 23:09 |
To the first question, you need to ensure that the pointer is non-null before accessing it. You can disable your udf for first few iterations then enable it, or you can check the pointer of C_T_G in your udf.
To the second question, the UDSIs are governed by the convection-diffusion equation. For each iteration/time step, they are set with the value of temperature gradient but they will change according to their governing equations. Dr Bill Wangard provided a solution for gradients calculation in this forum. You can search his threads for the solution. |
August 5, 2014, 05:29 |
Rep Power: 12 |
Thank you blackmask for your answer!
I added an If statement with a condition on storage and it works. But I have a doubt. Indeed, if I try to verify iterations in the cells, and I found out that iterations are less than the real number of cells. For example, I have 2048 cells while I got 1040 iterations. It means that UDS for some cells qre not allocated. How can I solve this? Thank you very much for your help!!! thread_loop_c (t,d) { if (NULL != THREAD_STORAGE(t,SV_UDS_I(0))&& NULL != THREAD_STORAGE(t,SV_UDS_I(1))&& NULL != THREAD_STORAGE(t,SV_UDS_I(2))) { k=0; begin_c_loop (c,t) { C_UDSI(c,t,0)=C_T_G(c,t)[0]; C_UDSI(c,t,1)=C_T_G(c,t)[1]; C_UDSI(c,t,2)=C_T_G(c,t)[2]; k+=1; printf("cell number%d \n", k); } end_c_loop (c,t) } } |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
Static Temperature / Opening Temperature | JulianP | CFX | 12 | April 10, 2019 19:00 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
laplacian of temperature | seyed Farid hosseinizadeh | FLUENT | 0 | December 17, 2006 22:56 |
