Help Please, face_t f, parse error
Old   July 21, 2014, 18:49
Default Help Please, face_t f, parse error
Guy
kookguy is on a distinguished road
I am new to writing UDFs for FLUENT (launched from Workbench). I am trying to interpreted a UDF source code for a tangential mass flow (compressible flow) for the first time but then I got stuck with errors.
Here is some information regarding my Fluent setting:
Version: 13.0.0
Working Directory: C:\Users\Kookguy
FLUENT ROOT Path: C:\Program Files\ANSYS Inc\v130/fluent
The following is my UDF source file, "myudfexample.c":
myudfexample.c
UDF for specifying swirling flow
#include "udf.h"
DEFINE_PROFILE(inlet_tangential_massflow, thread, position)
real x[ND_ND];
real y,z,r;
y=x[1];
z=x[2];
face_t f;
begin_f_loop(f,thread)
F_CENTROID(x, f, thread);
r=sqrt(pow(y,2)+pow(z,2)); /*acquiring radius*/
F_PROFILE(f, thread, position) = (r/0.01)*(0.5775); /*S=0.385, so (V=0.5775*U)*/
end_f_loop(f, thread)
Here are the errors I got as I interpreted the file (also shows my source file location):
Error: C:\Users\Kookguy\Desktop\ColdFlow\Sim5_try3_files\ dp0\FFF\Fluent\myudfexample.c: line 13: parse error.
Error: C:\Users\Kookguy\Desktop\ColdFlow\Sim5_try3_files\ dp0\FFF\Fluent\myudfexample.c: line 15: f: undeclared variable
where line 13, I believe is corresponded to face_t f, which causes subsequent problem in line 15.
What am I doing wrong here? Please Help!!
kookguy is offline   Reply With Quote
Old   July 22, 2014, 08:12
David
GM_XIII is on a distinguished road
Are you compiling or interpreting it?
pd: it also seems to me that x and y are always 0 check it
GM_XIII is offline   Reply With Quote
Old   July 22, 2014, 09:02
Gonzalo
gfoam is on a distinguished road
Hi:
i think that you have to do the statements y=x[1]; and z=x[2]; after calculating 'x' in the statement F_CENTROID(x, f, thread);, otherwise you will get the initial value of X[1] and X[2] for y and z. Regards
Gonzalo
gfoam is offline   Reply With Quote
Old   July 24, 2014, 19:43
Guy
Thank you very much for the comments!
GM_III, I was just interpreting the file. Do I have to compile it first? Any quick guidance of how and why to do that? Thank you very much for your help.
gfoam, I will change that!, again Thank you so much!
Hopefully, it will be all clear to me once I got the first file running; however, I'm still stuck at the moment.
Old   July 25, 2014, 12:11
Gonzalo
Hi:
I don't think you have to compile it because it's a very simple UDF and it serves only on the porpouse of initializing a BC's. But the UDF seems to bo OK if you change the statement I said to you before. Now, how are you trying to execute it? What variable type is "position" and how are you passing it to the UDF?
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
