June 13, 2014, 00:11 |
second derivation of temperature
Rep Power: 12 |
Hi,everyone!
I want to define a source term including the second derivation of temperature. I use the macros DEFINE_SOURCE and DEFINF_ADJUST. Here is the code: DEFINE_ADJUST(my_adjust,d) { Thread *t; cell_t c; if (! Data_Valid_P()) return; thread_loop_c(t,d) { begin_c_loop(c,t) { C_UDSI(c,t,1)=C_T_G(c,t)[0]; C_UDSI(c,t,2)=C_T_G(c,t)[1]; C_UDSI(c,t,3)=C_T_G(c,t)[2]; } end_c_loop(c,t) } } DEFINE_SOURCE(uds_source, c, t, dS, eqn) { real source; source=-0.000143472*(C_UDSI_G(c,t,1)[0]+C_UDSI_G(c,t,2)[1]+C_UDSI_G(c,t,3)[2]); dS[eqn]=0; return source; } I use an interpreted udf. I've tried solve/set/expert temporary solver memory [yes], and iterated some steps before hooking DEFINE_ADJUST. After I hook DEFINE_ADJUST, it can calculate without any problems. But once I include the source term, I meet the error access_violation. Can you help me with some advice on my problem. I am looking forward to your reply. Thank you in advance. sunjian |
June 13, 2014, 04:43 |
Rep Power: 27 |
Do you get the same error if you replace the line
source=-0.000143472*(C_UDSI_G(c,t,1)[0]+C_UDSI_G(c,t,2)[1]+C_UDSI_G(c,t,3)[2]); Code:
source=-0.000143472*(C_UDSI(c,t,1)[0]+C_UDSI(c,t,2)[1]+C_UDSI(c,t,3)[2]); Having this information might bring you one small step closer to the solution... |
June 13, 2014, 09:27 |
Rep Power: 12 |
Hi, pakk. Thank you for your reply. I replace the line
CODE: source=-0.000143472*(C_UDSI_G(c,t,1)[0]+C_UDSI_G(c,t,2)[1]+C_UDSI_G(c,t,3)[2]); with the following line CODE: source=-0.000143472*(C_UDSI(c,t,1)+C_UDSI(c,t,2)+C_UDSI(c, t,3)); Then I get the same error. You said maybe the uds is not defined. But what can I do to solve this problem? Is there something wrong in DEFINE_ADJUST? |
June 13, 2014, 10:52 |
Rep Power: 27 |
Try to plot the UDS. Is it zero on some parts of your domain? Then something is wrong in the adjust-part, maybe it did not hook to all cell zones.
Otherwise, I would have to think really hard. |
June 15, 2014, 06:23 |
Rep Power: 12 |
Hi, pakk. It's very nice of you to reply. Thank you again.
I tried to iterated with hooking the adjust-part and without including UDS transport equation 0 (I need to obtain User Scalar 0 in this equation) because as long as I include UDS transport equation 0, I will get the error access_violation. And I found that User Scalar 1, User Scalar 2 and User Scalar 3 were mostly not zero, though in some parts they might be zero (most of the values were near zero). On this occasion, is something wrong in the adjust-part? |
June 18, 2014, 03:50 |
Rep Power: 12 |
Hi,pakk.
I read a UDF showgrad.c in section Gradient(G) and Reconstruction Gradient(RG) Vector Macros in UDF Manual. I include the code below in my code. CODE: DEFINE_ON_DEMAND(showgrad) { Domain *domain; Thread *t; domain=Get_Domain(1); if (! Data_Valid_P()) return; Message0(" >>> entering show-grad: \n "); thread_loop_c(t, domain) { Message0("::::\n "); Message0(":::: Gradients :::: \n "); Message0("::::\n "); if (NNULLP(THREAD_STORAGE(t, SV_T_G))) { Message0("Gradient of T is available \n "); } if (NNULLP(T_STORAGE_R_NV(t,SV_UDSI_G(1)))) { Message0("Gradient of UDSI(1) is available \n "); } if (NNULLP(T_STORAGE_R_NV(t,SV_UDSI_G(2)))) { Message0("Gradient of UDSI(2) is available \n "); } if (NNULLP(T_STORAGE_R_NV(t,SV_UDSI_G(3)))) { Message0("Gradient of UDSI(3) is available \n "); } } } After the calculation with attaching the adjust-part and without attaching UDS transport equation 0, showgrad is executed and shows gradient of T, UDSI(1), UDSI(2) and UDSI(3) are available. So I think maybe the error happens in the source in UDS transport equation 0. Am I right? The source term is Laplacian of temperature as follows: source=a*(d2T/dX2+d2T/dY2+d2T/dZ2) My code is: DEFINE_SOURCE(uds_source, c, t, dS, eqn) { real source; source=-0.000143472*(C_UDSI_G(c,t,1)[0]+C_UDSI_G(c,t,2)[1]+C_UDSI_G(c,t,3)[2]); dS[eqn]=0; return source; } But I can't find any problem here. Can you give some suggestions? I'm looking forward to you reply. Thank you. |
June 18, 2014, 04:16 |
Rep Power: 27 |
Simplify your uds_source until it works. In that way you might identify in which step the problem occurs.
Some suggestions: Code:
DEFINE_SOURCE(uds_source, c, t, dS, eqn) { real source; source=-0.000143472*(C_UDSI_G(c,t,1)[0]); dS[eqn]=0; return source; } Code:
DEFINE_SOURCE(uds_source, c, t, dS, eqn) { real source; source=-0.000143472*(C_UDSI(c,t,1)[0]); dS[eqn]=0; return source; } Code:
DEFINE_SOURCE(uds_source, c, t, dS, eqn) { real source; source=-0.000143472; dS[eqn]=0; return source; } |
June 19, 2014, 05:06 |
Rep Power: 12 |
Hi, pakk. Thank you for your help!
I've found where the error happens. In my UDF, I also define a UDS flux for UDS transport equation 0. I want to obtain the flux that equals the negative product of density and velocity. I use the code below firstly: DEFINE_UDS_FLUX(A_flux, f, t, i) { real NV_VEC(vec), NV_VEC(A),dens,flux; F_AREA(A, f, t); dens=F_R(f,t); NV_DS(vec,=,F_U(f,t),F_V(f,t),F_W(f,t),*,dens); flux=NV_DOT(vec,A); return - flux; } The error access_violation always occurs. Then I try the code below: DEFINE_UDS_FLUX(A_flux, f, t, i) { return - F_FLUX(f,t); } It can iterate now. Both of the codes can be compiled without any error. Do you know what the mistake is in the first code? Best regards. |
June 19, 2014, 06:04 |
#9 |
Rep Power: 27 |
You should look at the example in the manual for DEFINE_UDS_FLUX. It has a comment about the density not being available for all BCs, and how to solve it. I don't know if this is causing the problem, but you could try it.
June 23, 2014, 06:32 |
#10 |
Rep Power: 12 |
Hi, pakk. I have another question about the outlet boundary condition. I simulate the heat transfer in duct. For the inlet, I set the velocity-inlet condition and the user scalar 0 is set constant value 0. Here's no question. But for the fully-developed flow, I set the outflow condition and the BC should be (A*)inlet = (A*)outlet, where A is user scalar 0. For BC like this, how can I define it? I couldn't find a similar example in UDF manual. Could you help me with some clue? Thank you very much.
June 23, 2014, 06:55 |
#11 |
Rep Power: 27 |
June 23, 2014, 11:25 |
#12 |
Rep Power: 12 |
July 18, 2014, 09:53 |
#13 |
Rep Power: 12 |
Hi everyone!!
I have a similar problem. I'm trying to calculate the laplacian of temperature field in order to introduce it into the source terme of energy equation. Here there is a simplification of my C code. DEFINE_ADJUST(adjust_gradient, domain) { Thread *t; cell_t c; if (! Data_Valid_P()) return; thread_loop_c (t,domain) { begin_c_loop (c,t) { C_UDSI(c,t,0)=C_T_RG(c,t)[0]; C_UDSI(c,t,1)=C_T_RG(c,t)[1]; C_UDSI(c,t,2)=C_T_RG(c,t)[2]; } end_c_loop (c,t) } } DEFINE_SOURCE(energy_source,c,t,ds,eqn) { real source; source=20*C_UDSI(c,t,0); C_UDMI(c,t,0)=C_UDSI(c,t,0); C_UDMI(c,t,1)=source; C_UDMI(c,t,2)=C_UDSI_G(c,t,0)[0]; /*some calculus for testing the data*/ C_UDMI(c,t,3)=1/C_UDSI_G(c,t,0)[0]; C_UDMI(c,t,4)=100*C_UDSI_G(c,t,0)[0]; ds[eqn]=0; return source; } The operations I make are:
SO I have 2 principal problems:
Is there someone who can help me, pleeease??? Thank you guys!!! Stefano |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
Static Temperature / Opening Temperature | JulianP | CFX | 12 | April 10, 2019 19:00 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
Is wall ajacent temperature equal to conservative temperature of the wall? | shenying0710 | CFX | 8 | January 4, 2013 05:03 |
