June 10, 2014, 12:07 |
UDF error for flux
oguzayin
Rep Power: 12 |
Hi All,
i am trying to solve transport equation in fluent with udf. I wrote the udf for this and it is well compiled but when i run the simulation it gives error. please help me ? My Udf is as follows #include"udf.h" #define dp 150.e-6 #define miu 1.7894e-5 #define rho 1.225 #define Cc (1.+0.066e-6/dp*(2.34+1.05*exp(-0.39*dp/0.066e-6))) #define vs_x 0.0 #define vs_y (-998.2*dp*dp*9.81*Cc/(18.*miu)) #define vs_z 0.0 // dp=particle diameter // miu=air densty //rho=air density //vk=kinematic viscisity of air //Cc=cunningham correction factor //Brownian=Brownian diffusion coefficient //Sc=Schmidt number //Sc3=pow(Sc,-1/3.) //vs_x=x component of the settling velocity //vs_y=y component of the settling velocity //vs_z=z component of the settling velocity /************************************************** *********************/ /* UDF to add gravitational settling velocity into the convective term */ /* of particle species conservation equation */ /************************************************** *********************/ DEFINE_UDS_FLUX(particle_flux, f, t, i) { real NV_VEC(vs_vec), NV_VEC(A); real settling_flux; real x[ND_ND]; // vs_vec=settling velocity vector // A=face normal vector // settling_flux=particle settling flux, which is a scalar // x=position of face centroid /* Define the settling velocity vector */ NV_D(vs_vec, = , vs_x, vs_y, vs_z); /* obtain the face normal vector of the current face */ F_AREA(A, f, t); /* calculate the superimposed mass flow vector */ if (!BOUNDARY_FACE_THREAD_P(t)) settling_flux = NV_DOT(vs_vec, A); else settling_flux = 0.0; return (F_FLUX(f, t) / rho + settling_flux); } |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 08:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 22:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 05:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
