Rep Power: 12 ![]() |
Hi, I am having problem with an if else statement for a UDF. It seems not to work. Please can anyone see what am not doing right.
DEFINE_ADJUST(experiment,domain) { Thread *t; cell_t c; real Z,l_x,A,x_p; thread_loop_c (t,domain) { Thread **pt = THREAD_SUB_THREADS(t); Thread *tp = pt[0]; /* gas phase */ Thread *ts = pt[1]; /* solid phase */ if (NULL != THREAD_STORAGE(t,SV_UDS_I(ADS))&& NULL != T_STORAGE_R_NV(t,SV_UDSI_M1(ADS))) { begin_c_loop (c,t) { if (C_VOF(c,ts) >= 0.00001) { Z = 4675.47; x_p = 526890/C_UDSI(c,t,P); l_x = log(x_p); A = 8.31429*tem*l_x; C_UDSI(c,t,ADS)=0.301555862*exp(-(A*A*A)/(Z*Z*Z)); } else { Z = 4675.47; x_p = 526890/C_UDSI(c,t,P); l_x = log(x_p); A = 8.31429*tem*l_x; C_UDSI(c,t,ADS)=0; } } end_c_loop(c,t) } } } C_UDSI(c,t,ADS)=0 is meant to be case when volume fraction of solid is less than 0.00001 but this is not happening for me in the simulation. |
I had some similar issues and just use put another if with the inverse statement. In your case it would be
if (C_VOF(c,ts) < 0.00001) It is anoying because it is slower but it works. |
Thanks Crow. I don't seem to understand what you mean. Are you saying I should use another if with inverse of the logical expression instead of else logical expression in which case it will become
if (C_VOF(c,ts) >= 0.00001) { Z = 4675.47; x_p = 526890/C_UDSI(c,t,P); l_x = log(x_p); A = 8.31429*tem*l_x; C_UDSI(c,t,ADS)=0.301555862*exp(-(A*A*A)/(Z*Z*Z)); } if (C_VOF(c,ts) < 0.00001) { Z = 4675.47; x_p = 526890/C_UDSI(c,t,P); l_x = log(x_p); A = 8.31429*tem*l_x; C_UDSI(c,t,ADS)=0; } } end_c_loop(c,t) } } } Thanks |
Yes, this is what I mean. So if the problem is with the if else statement it should solve it. If I'm not mistaken, it should make your code looks like this:
DEFINE_ADJUST(experiment,domain) { Thread *t; cell_t c; real Z,l_x,A,x_p; thread_loop_c (t,domain) { Thread **pt = THREAD_SUB_THREADS(t); Thread *tp = pt[0]; /* gas phase */ Thread *ts = pt[1]; /* solid phase */ if (NULL != THREAD_STORAGE(t,SV_UDS_I(ADS))&& NULL != T_STORAGE_R_NV(t,SV_UDSI_M1(ADS))) { begin_c_loop (c,t) { if (C_VOF(c,ts) >= 0.00001) { Z = 4675.47; x_p = 526890/C_UDSI(c,t,P); l_x = log(x_p); A = 8.31429*tem*l_x; C_UDSI(c,t,ADS)=0.301555862*exp(-(A*A*A)/(Z*Z*Z)); } if (C_VOF(c,ts) < 0.00001) { Z = 4675.47; x_p = 526890/C_UDSI(c,t,P); l_x = log(x_p); A = 8.31429*tem*l_x; C_UDSI(c,t,ADS)=0; } } end_c_loop(c,t) } } } |
Thanks Crow. I have done exactly that and yet it is not working. Was your case similar to mine? If yes did you do any other thing different and how long did your simulation run for?
Thanks |
More information is needed in order to help you.
1) What are you trying to accomplish exactly with your UDF? 2) What is the error message/problem you are encounting to know that your UDF is not working? Edit: 3) What is the general configuration of your simulation? What are you simulating? |
if else statement, udf, uds, volume fraction |
Help with if statement | CHARLES | OpenFOAM Programming & Development | 17 | August 22, 2021 03:14 |
Restricting area in if statement | Blackhawks84 | Fluent UDF and Scheme Programming | 4 | July 22, 2012 16:50 |
If statement question | mariam.sara | CFX | 3 | May 24, 2012 02:33 |
Weak statement for Galerkin Method | rugabug | Main CFD Forum | 0 | March 26, 2010 19:19 |
Problem Statement | balkrishna | Main CFD Forum | 0 | October 6, 2009 23:55 |
