Stop particle trajectory in DPM
Old   June 5, 2014, 13:31
Default Stop particle trajectory in DPM
oball is on a distinguished road
Hello, i am using FLUENT DPM to do particle tracking. And for my case, particles need to be considered as trapped when certain conditions satisfied, without ever hit the boundaries. I am now using a UDF to check whether the conditions are satisfied after each DPM time step, but don't know how to tell FLUENT that the particles need to be considered as "trapped" and stop the tracking for that particles. Can anyone know the macro or variables in DPM that i can access in UDF to do this job? Thank you so much!
oball is offline   Reply With Quote
Old   June 9, 2014, 12:28
upeksa is on a distinguished road
It's easy:
DEFINE_DPM_BC(name,p,t,f,f_normal,dim)
/*if reflected*/
return PATH_ACTIVE;
/*if trapped*/
return PATH_ABORT;
/*if escaped*/
return PATH_END;
You have some examples in your UDF Guide, check it for further information.
Cheers
upeksa is offline   Reply With Quote
Old   June 9, 2014, 13:48
Hi, upeksa,
Thank you for the reply! My problem is the DEFINE_DPM_BC macro will only be executed when the particle center hit the wall boundaries. While for my case, I need to stop the particles before that (when the particle surface hit the wall). I am now using DEFINE_DPM_SCALAR_UPDATE macro to make the judgement (when the particle should be stopped), but do you think we can force FLUENT to execute DEFINE_DPM_BC at a user defined condition? Thank you!!
oball
Old   June 10, 2014, 08:47
I am not sure, I have never used DPM macros that way.
Try something like:
DEFINE_DPM_SCALAR_UPDATE(arguments)
/*if I want the particle to stop*/
for (i=0;i<dim;i++)
P_VEL0[i]=0.0;
Let me know if it worked.
Cheers
Old   June 11, 2014, 01:52
gearboy is on a distinguished road
p->stream_index = -1;
gearboy is offline   Reply With Quote
Old   June 27, 2014, 16:53
Just heard from ANSYS tech service, MARK_PARTICLE(p, P_FL_REMOVED) will work. It will stop the trajectory tracking for that particle and count it as trapped.
Old   July 23, 2014, 17:38
Ebrahim
Ebrahim is on a distinguished road
Hello Oball,
Does the above macro work for you? I used it with FLUENT 6.3 but faced with this error:
"error C2065: 'P_FL_REMOVED' : undeclared identifier"
Is it only usable in ANSYS_FLUENT or can be used in FLUENT 6.3 as well?
Thanks
Ebrahim is offline   Reply With Quote
Old   November 14, 2016, 16:35
raa
rdfing is on a distinguished road
I don't see how MARK_PARTICLE(p, P_FL_REMOVED) would be different from p->stream_index = -1
rdfing is offline   Reply With Quote
Old   November 18, 2016, 10:11
pakk will become famous soon enough
It would be in possible future versions of Fluent where they change the structure of the data, such that p->stream_index is no longer the working.
Even if now "MARK_PARTICLE(p, P_FL_REMOVED)" is a macro that becomes "p->stream_index = -1", it does not have to stay this way. If you want to have more certainty that your code will run in future versions of Fluent, use the interface that the developers give you.
pakk is offline   Reply With Quote
DPM: Particle tracks stop at a "reflect" surface Confused FLUENT 3 February 7, 2022 13:12
DPM particle tracking considering particle size oball Fluent UDF and Scheme Programming 4 October 6, 2019 15:42
injection problem Mark New FLUENT 0 August 4, 2013 02:30
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
DPM particle trajectory hedonist FLUENT 0 April 4, 2003 00:13
