DPM particle tracking considering particle size |
May 31, 2014, 07:22 |
Rep Power: 12 |
Hello, I am simulating the particle trajectory in a particle sampler using FLUENT DPM, in which i need to consider the particle collection by interception. That means when the distance between particle center and the wall is smaller than the particle radius, the particles should be considered as collected. However, particle-wall interaction only happened when the particle center hit the wall, not the edges, by default in FLUENT. I think I need to write a UDF to calculate the particle-wall distance and determine whether they touch or not. I am new to UDF. Can anyone ever deal with this problems and point me to some source that i can learn from. Thank you so much!!
August 25, 2014, 13:34 |
MarkClarence
Rep Power: 12 |
Could you write the UDF? Thank you. |
September 16, 2014, 13:45 |
MarkClarence
Rep Power: 12 |
If you were able to get the UDF please reply.
October 6, 2019, 14:49 |
surya
Rep Power: 11 |
hey,
pls help to write this udf... |
October 6, 2019, 15:42 |
Rep Power: 27 |
In DPM, particles are simulated as point particles. This is a very basic assumption. The diameter of particles should be much smaller than your typical opening, otherwise it makes no sense to use the method, and you should use a different method, such as 6DOF.
dpm, finite size, interception, particle tracking |
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump | scatman | CFX | 7 | January 8, 2018 01:59 |
Periodic Condition for Particle Tracking in DPM | vagaikwa | FLUENT | 2 | May 22, 2017 05:14 |
DPM particle tracking in stirred tank | parisa- | FLUENT | 1 | August 7, 2012 13:03 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
DPM: Particle Tracking | Madhukar | FLUENT | 1 | July 24, 2007 04:51 |
