UDF C_P(c,t) Define density initialization error
Old   May 29, 2014, 23:12
Smile UDF C_P(c,t) Define density initialization error
yuanmengyuan1989 is on a distinguished road
My udf is as following, it is just used to test the usage of C_P(c,t).
#include "udf.h"
#define RHOV 0.554
DEFINE_PROPERTY(density,c,t)
real rho;
real p = C_P(c,t);
rho = RHOV;
return rho;
but an error will appear as following.
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
as we can see in UDF, the density has nothing to do with the pressure. i doubt that it must be an error when C_P(c,t) is used. do you know what's wrong with it? thank you
yuanmengyuan1989 is offline   Reply With Quote
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
