Problems to loop one phase in multiphase using UDF(Solid+fluid zones, three phases)
Old   May 27, 2014, 12:31
Default Problems to loop one phase in multiphase using UDF(Solid+fluid zones, three phases)
Sean
songpen1985 is on a distinguished road
I have a compuational domain with two zones (fluid and solid). In the fluid zone, I have three phases (A, B and C). I want to adjust the properties of the cells in phase B. The udf can be interpreted and run.
However, if I check the UDMI, all the cells instead of phase B in the compuational domain (including solid and fluid) are controlled by the udf. I just want to control the cells in phase B. It seems that "sub_domain_loop" loops all the cells in all zones instead of the cells in phase B. Can you help to see the problem? Thank you!
DEFINE_ADJUST(name,mixture_domain)
int phase_domain_index=1; /*get the phase B*/
sub_domain_loop(subdomain, mixture_domain, phase_domain_index)
thread_loop_c(t,subdomain)
begin_c_loop_all(c,t)
UDMI(c,t,0)=...
songpen1985 is offline   Reply With Quote
Old   March 14, 2015, 20:42
Default UDF for multiphase flow identifier
Azharuddin
azharuddin0613 is on a distinguished road
I am trying to model a membrane for separation of gas from mixture of gas and solid. I have tried to write a udf for gas separation from a mixture of gases. What macros do I need to incorporate in my udf.
DEFINE_INIT(init_function,d)
Thread *tc1, *tc2;
Thread *tf1, *tf2;
cell_t c1, c2;
face_t f1, f2;
real f_c1[2], f_c2[2];
thread_loop_c(tc1,d)
begin_c_loop(c1,tc1)
C_UDMI(c1,tc1,UDM_NEIGHBOUR_C) = 0.0;
C_UDMI(c1,tc1,UDM_NEIGHBOUR_TC) = 0.0;
C_UDMI(c1,tc1,UDM_MASS_SOURCE) = 0.0;
end_c_loop(c1,tc1)
tf1 = Lookup_Thread(d,WALLSIDE1);
tf2 = Lookup_Thread(d,WALLSIDE2);
begin_f_loop(f1,tf1)
F_CENTROID(f_c1,f1,tf1);
c1 = F_C0(f1,tf1);
tc1 = THREAD_T0(tf1);
begin_f_loop(f2,tf2)
F_CENTROID(f_c2,f2,tf2);
if (fabs(f_c1[0]-f_c2[0]) <= TOLERANCE &&
fabs(f_c1[1]-f_c2[1]) <= TOLERANCE )
c2 = F_C0(f2,tf2);
tc2 = THREAD_T0(tf2);
C_UDMI(c1,tc1,UDM_NEIGHBOUR_C) = c2 + 0.1;
C_UDMI(c2,tc2,UDM_NEIGHBOUR_C) = c1 + 0.1;
C_UDMI(c1,tc1,UDM_NEIGHBOUR_TC) = THREAD_ID(tc2) + 0.1;
C_UDMI(c2,tc2,UDM_NEIGHBOUR_TC) = THREAD_ID(tc1) + 0.1;
end_f_loop(f2,tf2)
end_f_loop(f1,tf1)
Message("\n Membrane initialisation completed.\n");
azharuddin0613 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
fluid domain extraction for CHT problems bhanu1810 STAR-CCM+ 3 May 22, 2011 08:26
Phase Change Problems Jade M ANSYS 1 October 21, 2010 17:56
Problems with multiphase modeling magnounibo FLUENT 0 April 30, 2009 04:59
Non-newtonial Fluid Henry CFX 1 October 23, 2002 14:08
