May 7, 2014, 00:16 |
pressure profile UDF not compiling
uzi
Rep Power: 12 |
Hi
I tried to compile the example from the fluent help UDF for specifying steady-state parabolic pressure profile boundary profile for a turbine vane ************************************************** **********************/ #include "udf.h" DEFINE_PROFILE(pressure_profile,t,i) { real x[ND_ND]; /* this will hold the position vector */ real y; face_t f; begin_f_loop(f,t) { F_CENTROID(x,f,t); y = x[1]; F_PROFILE(f,t,i) = 1.1e5 - y*y/(.0745*.0745)*0.1e5; } end_f_loop(f,t) } and it gave me this messag: Copied d:\Users\rnds\Desktop\Udi Try\selfy_files\dp0\FFF\Fluent\selfy.c to d:\Users\rnds\Desktop\Udi Try\selfy_files\dp0\FFF\Fluent\libudf\src udf_names.c and user_nt.udf files in 2d are upto date. (system "copy "C:\PROGRA~1\ANSYSI~1\v150\fluent"\fluent15.0. 0\sr c\makefile_nt.udf "d:\Users\rnds\Desktop\Udi Try\selfy_files\dp0\FFF\Fluent\libudf\win64\2d\mak efile" ") 1 file(s) copied. (chdir "d:\Users\rnds\Desktop\Udi Try\selfy_files\dp0\FFF\Fluent\libudf")(chdir "win64\2d")udf_names.c udf_names.c(7) : error C2059: syntax error : '}' udf_names.c(8) : warning C4034: sizeof returns 0 dose some one know why? |
May 9, 2014, 11:13 |
hana
Rep Power: 12 |
without any changing of your code
I could compile in fluent successful. Maybe this is some technical problem. if you use window 7. please check something like a environment variable |
May 11, 2014, 00:21 |
uzi
Rep Power: 12 |
I will check.
thank you |
UDF for pressure profile at outlet: | sandeep_tu | Fluent UDF and Scheme Programming | 8 | December 3, 2014 13:17 |
how to get pressure and pressure gradient using UDF | Honglin | Fluent UDF and Scheme Programming | 0 | May 24, 2012 06:47 |
I want to use pressure of 1 face in udf that compiled on other face | iman_1844 | Fluent UDF and Scheme Programming | 3 | June 10, 2010 12:55 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
