Help!UDF viscosity
Old   May 5, 2014, 08:46
Default Help!UDF viscosity
Weiliang Hou
wyqhwl is on a distinguished road
I write a UDF viscosity code.I want to define a kind of non-newtonian fuild in laminar flow, and its viscosity is changed with time. But the viscosity is homegeneous in stirring and not shear thinning.The code is here.So I want to how I can modify this code. Thank you very much!
#include "udf.h"
DEFINE_PROPERTY(cell_viscosity,c,t)
real time,vis, s_mag,n,kp;
time = RP_Get_Real("flow-time");
s_mag=C_STRAIN_RATE_MAG(c,t);
if(time<32400)
kp=0.095552*pow(time/3600,4)-2.5696*pow(time/3600,3)+25.13*pow(time/3600,2)-107.13*time/3600+179;
n=0.000075452*pow(time/3600,6)-0.0020979*pow(time/3600,5)+0.022364*pow(time/3600,4)-0.11435*pow(time/3600,3)+0.28236*pow(time/3600,2)-0.23947*time/3600+0.214;
else
kp=3.82832;
n=0.518373;
s_mag=38.211*pow(1.11,2/n)*pow(n*(pow(1.11,2/n-1)-1)/(2-n)/0.11,1/(n-1))/(pow(1.21,2/n)-1)/n;
vis=kp*pow(s_mag,(n-1));
return vis;
wyqhwl is offline   Reply With Quote
non-newtonian fluid, viscosity udf
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 08:45
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 11:02
modelling solids viscosity in eulerian multiphase model derkaiser FLUENT 1 December 5, 2011 04:42
kinematic viscosity at diff temperatures,pressures Mecobio Main CFD Forum 0 November 7, 2005 13:55
