Is it possible to define a time-dependent velocity field by UDF |
May 3, 2014, 22:25 |
Zh
Rep Power: 14 |
Hi all,
I am doing multiphase flow simulation, and I'd like to do a validation case to evaluate the performance of VOF method in FLUENT. In order to simulate the validation case, the velocity field needs to be defined as: u=sin^2(πx)sin(2πy)cos(πt/T) v=cos^2(πy)sin(2πx)cos(πt/T) How should I define the time-depedent velocity field in FLUENT, is UDF a practical solution ? Any suggestion is welcome, thanks in advance |
multiphase flow, udf code |
HELP----Surface Reaction UDF | Ashi | Fluent UDF and Scheme Programming | 1 | May 19, 2020 21:13 |
Problem in UDF time dependent vloumetric heat source | eng_yasser_2020 | Fluent UDF and Scheme Programming | 0 | March 30, 2014 08:07 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
time dependent velocity input by user subroutine | shohel mahmud | Siemens | 4 | December 18, 2007 11:40 |
