Varying mass flow at an inlet boundary condition. Fuel mass flow.
Like Tree5Likes
Old   February 26, 2015, 06:25
pakk will become famous soon enough
Ok, then your basic layout for the execute-at-end should be:
- start with SUMMEDVOLUME=0 and SUMMEDFRACTION=0
- go through all fluid bodies. for each fluid body:
- go through all cells. for each cell:
- add the volume to SUMMEDVOLUME
- add the co2 fraction to SUMMEDFRACTION
- at the end, calculate SUMMEDFRACTION/SUMMEDVOLUME, and store that in a global variable.
This is what I mean by describing what the code should do. Try to think like the computer, and list the steps that the computer should take. That is the real programming part. Finding out how to put this in a programming language is not the crucial part of programming.
Can you understand the basic layout for the execute-at-end? And do you think it is correct? If so, try to translate this into code. At first, don't care if the computer does not understand what you want, we can help you with the exact syntax.
And try to do something similar for the PROFILE-part.
pakk is offline   Reply With Quote
Old   March 3, 2015, 02:58
Default UDF for mass flow rate varying with time
  #62
Nikhil P
nikhilpolpakkara is on a distinguished road
I am beginner in using UDF. i need to give a mass flow rate at inlet which is varying with respect to time. i have created an incomplete UDF. i have a function of which is a polynomial of order 6. can anyone help me with this.
#include "udf.h"
DEFINE_PROFILE(inlet_MF, thread, index)
real t;
face_t f;
begin_f_loop(f, thread)
for- /* for time = .0001s to .01410s with .0001 increment */
F_profile(f,thread,index)= -8E+10x6 + 3E+09x5 - 3E+07x4 + 185890x3 - 492.49x2 + 0.5817x - 4E-06
} end_f_loop()
nikhilpolpakkara is offline   Reply With Quote
Old   March 3, 2015, 05:12
You don't need to set this in the UDF, you set the time in Fluent using the transient settings.
Then, you can just use
t=CURRENT_TIME
(and replace x by t in your code...)
nikhilpolpakkara likes this.
Old   March 5, 2015, 01:19
AH
visitor is on a distinguished road
Dear Pakk
Just to let you know that I am not ignoring your message. We are approaching end of year exams, difficult to find a computer. Just managed half and hour access this week.
Regards.
visitor is offline   Reply With Quote
Old   March 20, 2015, 00:26
Default udf for yransient mass flow inlet
  #65
Nikhil P
I have been trying to simulate a transient mass flow rate condition. I have mass flow rate in terms of time as a 6th order polinomial equation . How can I give the udf for the same ? Please help
Old   March 20, 2015, 03:55
See your question and my answer on 3 March.
Weird... Why do you repeat this question, if you already have an answer? If the answer was not sufficient, then say so.
Old   March 20, 2015, 05:39
Nikhil P
Sorry that i repeated the same question, i will be more precise.
#include "udf.h"
DEFINE_PROFILE(inlet_mf, thread, index)
float t = CURRENT_TIME;
face_t f;
F_PROFILE(f, thread, index) = -(20000000000*t*t*t*t*t*t) + (700000000*t*t*t*t*t) - (8000000*t*t*t*t) + (46473*t*t*t) - (123.12*t*t) + (0.1454*t) - 0.000001;
end_f_loop(f, thread)
this is the udf i created. will this udf give me a mass flow rate at each .1 millisecond according to the profile thats mentioned? i am able to run the calculation but my solution is not converging.
PS : the solution given last time was helpful.
Old   March 20, 2015, 05:52
Don't ask us, just check this in your simulation results!
Even if they are not converged, they show the mass-flow through your inlet.
Old   March 20, 2015, 05:55
`e`
`e` is on a distinguished road
If your time step is 0.1 ms and your profile is updated at every time step then I'd expect the mass flow rate would be applied every 0.1 ms.
`e` is offline   Reply With Quote
Old   March 20, 2015, 06:03
Nikhil P
thank you for the help
Old   October 30, 2017, 17:38
Default stop program by missed semicolons
  #71
mrwan
mrwan is on a distinguished road
#include "udf.h"
DEFINE_PROFILE(vary,t,i)
real pressure;
face_t f;
begin_f_loop(f,t)
pressure = F_P(f,t);
if(pressure <= 0)
F_PROFILE(f,t,i) = 1;
else
F_PROFILE(f,t,i) = 0;
end_f_loop(f,t)
this is correct
mrwan is offline   Reply With Quote
Boudaries for bouynat driven flow with additional mass flux at inlet Charon CFX 2 April 27, 2013 09:02
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
velocity calculations in mass flow inlet boundary condition montazer1012 FLUENT 1 October 18, 2010 04:11
Mass flow boundary condition Renato. Main CFD Forum 0 July 21, 2006 23:07
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
