udf for mass transfer
Old   April 19, 2014, 04:46
Default udf for mass transfer
sarighulikhan
hane is on a distinguished road
i need to wright a udf for mass transfer(diffusion)
phenol is diffusing from oil to water through interface
would you guide me in this regard?
i mean which macro should i use?
is it possible to write udf for this?
is there any ready example availabe for this?
it is very urgent , i would be thankful if u.....
thanks & regards
hane is offline   Reply With Quote
Old   April 19, 2014, 14:40
Mahesh
Dinesh Yadav is on a distinguished road
I am not very sure as i am also new to write UDF. You may try DEFINE_MASS_TRANSFER functions. You need to write your diffusion equation for mass transfer in codes. You may look for some other help as i am also a beginner in UDF.
Good Luck......
thanks & regards
Dinesh Yadav is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
UDF for hear transfer coefficient in non-thermal equilibrium porous meda sheeko Fluent UDF and Scheme Programming 8 January 2, 2020 00:43
UDF to change heat transfer coefficient eng_yasser_2020 Fluent UDF and Scheme Programming 1 July 1, 2016 10:47
Mass transfer UDF expecting void return Quinos Fluent UDF and Scheme Programming 0 January 8, 2014 19:36
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
