April 8, 2014, 10:12 |
UDF problems with porous flow
Nick
Rep Power: 14 |
Hi everyone,
I have a problem with my porous flow UDFs. My geometry is a simple 2D channel with a porous region blocking flow. I specify a pressure inlet and outlet. When solving my problem with the porous flow solver in Fluent, I get a nice reasonable flow. But when I do it with a UDF defining porous flow with a source UDF, I get the same result except some very ugly redlines going into and out of the porous region that are entirely unexpected (see image). My UDFs should be fine as they are simple Darcian flow so I wonder what is wrong? I suspect it is the mesh, but I would really appreciate advice on what to do. Thanks, Nick Here is my Porous flow UDF #include "udf.h" #define urf 0.1 // under-relaxation factor real s1 = 0. , s2 = 0.; DEFINE_SOURCE(Darcian_x,c,t,dS,eqn) { //k is the permeability, defined in m^2 real source, k, mu; mu = C_MU_L(c,t); k = 1.4E-11; source = - C_U(c,t)*mu/k; dS[eqn] = - mu/k; s1 = s1*(1-urf) + source*urf; return s1; } DEFINE_SOURCE(Darcian_y,c,t,dS,eqn) { //k is the permeability, defined in m^2 real source, k, mu; mu = C_MU_L(c,t); k = 1E-20; source = - C_V(c,t)*mu/k; dS[eqn] = - mu/k; s2 = s2*(1-urf) + source*urf; return s2; } |
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) | florian_krause | OpenFOAM | 22 | June 13, 2013 22:25 |
Porous Media coupled with internal flow | Samuel Andrade | FLUENT | 2 | August 26, 2012 10:43 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 07:44 |
unexpected flow speeds within porous zones | MasterCooler | OpenFOAM | 11 | May 2, 2012 08:48 |
compressible flow through porous media | Chirag2302 | FLUENT | 0 | March 3, 2012 00:13 |
