April 5, 2014, 04:25 |
Verification of UDF - getting errors
karthik kondaveeti
I am a beginner in wirting UDF's, Currently I need to write UDF for vatiation of Specific heat based on pressure and temperature. In a nutshell, Cp will be calculated at P = 1atm and at P = 10atm. Now, a log interpolation is used to find the Cp value in the interim pressure points. Here is the UDF., while interpreting, I an getting errors like "function returning float returns double" "coeffCp1: argument 1 type mismatch (pointer to double instead of pointer to float)" Please help me Thank you /*Make sure the units of pressure is Atm, Cp in cal/g-k and temp in K*/ #include <stdio.h> #include "udf.h" /* Specific heat for 1 atmosphere */ void coeffCp1(double *Acp, double *Bcp, double *Ccp, double *Dcp, double *Ecp, double input_temp) { if (input_temp < 500) { (*Acp) = 0; (*Bcp) = 0; (*Ccp) = 0; (*Dcp) = 0; (*Ecp) = 0.24; } else if (input_temp >= 500 && input_temp < 1750) { (*Acp) = 0.164992; (*Bcp) = 0.156336e1; (*Ccp) = 0.552429e1; (*Dcp) = 0.879873e1; (*Ecp) = 0.412806e1; } else if (input_temp >= 1750 && input_temp < 3250) { (*Acp) = -0.830572e1; (*Bcp) = -0.483112e2; (*Ccp) = -0.101598e3; (*Dcp) = -0.897230e2; (*Ecp) = -0.280651e2; } else if (input_temp >= 3250 && input_temp < 4750) { (*Acp) = 0.848335e2; (*Bcp) = 0.361629e3; (*Ccp) = 0.561712e3; (*Dcp) = 0.376565e3; (*Ecp) = 0.915792e2; } else if (input_temp >= 4750 && input_temp < 7750) { (*Acp) = -0.945467e1; (*Bcp) = -0.640807e2; (*Ccp) = -0.893740e2; (*Dcp) = -0.403342e2; (*Ecp) = -0.458728e1; } else if (input_temp >= 7750 && input_temp < 11750) { (*Acp) = -0.153176e3; (*Bcp) = -0.476111e2; (*Ccp) = 0.217674e2; (*Dcp) = 0.314736e1; (*Ecp) = 0.922570e-1; } else if (input_temp >= 11750 && input_temp < 20500) { (*Acp) = 0.975058e2; (*Bcp) = -0.158721e3; (*Ccp) = 0.753693e2; (*Dcp) = -0.936668e1; (*Ecp) = 0.987515e0; } else { (*Acp) = -0.473648e2; (*Bcp) = 0.818135e2; (*Ccp) = 0.169726e2; (*Dcp) = -0.836769e2; (*Ecp) = 0.339060e2; } } /* Specific heat for 10 atmosphere */ void coeffCp10(double *Acp, double *Bcp, double *Ccp, double *Dcp, double *Ecp, double input_temp) { if (input_temp < 500) { (*Acp) = 0; (*Bcp) = 0; (*Ccp) = 0; (*Dcp) = 0; (*Ecp) = 0.24; } else if (input_temp >= 500 && input_temp < 1750) { (*Acp) = 0.111751; (*Bcp) = 0.105018e1; (*Ccp) = 0.368846e1; (*Dcp) = 0.591074e1; (*Ecp) = 0.244269e1; } else if (input_temp >= 1750 && input_temp < 3250) { (*Acp) = 0.252675; (*Bcp) = 0.341131e1; (*Ccp) = 0.131529e2; (*Dcp) = 0.203259e2; (*Ecp) = 0.100197e2; } else if (input_temp >= 3250 && input_temp < 5750) { (*Acp) = 0.450386e2; (*Bcp) = 0.167261e3; (*Ccp) = 0.224426e3; (*Dcp) = 0.128924e3; (*Ecp) = 0.263694e2; } else if (input_temp >= 5750 && input_temp < 9250) { (*Acp) = 0.231376e2; (*Bcp) = -0.104484e1; (*Ccp) = -0.271807e2; (*Dcp) = -0.102436e2; (*Ecp) = -0.333185e-1; } else if (input_temp >= 9250 && input_temp < 13750) { (*Acp) = -0.799940e2; (*Bcp) = 0.170114e2; (*Ccp) = 0.187072e2; (*Dcp) = -0.350311e1; (*Ecp) = 0.184168e0; } else if (input_temp >= 13750 && input_temp < 22500) { (*Acp) = 0.491689e2; (*Bcp) = -0.116351e3; (*Ccp) = 0.889977e2; (*Dcp) = -0.242638e2; (*Ecp) = 0.263659e1; } else { (*Acp) = -0.253231e3; (*Bcp) = 0.955890e3; (*Ccp) = -0.132457e4; (*Dcp) = 0.798459e3; (*Ecp) = -0.175990e3; } } double compute_cp(double input_temp, double input_pressure) { double Acp, Bcp, Ccp, Dcp, Ecp; double Cp1, Cp10; double P2 = 1.01325e7, P1=1.01325e5; double Y = input_temp/1000.0; coeffCp1(&Acp,&Bcp,&Ccp,&Dcp,&Ecp,input_temp); Cp1 = exp(Acp*Y*Y*Y*Y + Bcp*Y*Y*Y + Ccp*Y*Y + Dcp*Y + Ecp); coeffCp10(&Acp,&Bcp,&Ccp,&Dcp,&Ecp,input_temp); Cp10 = exp(Acp*Y*Y*Y*Y + Bcp*Y*Y*Y + Ccp*Y*Y + Dcp*Y + Ecp); if (input_pressure < 1 && input_pressure > 1.0e7) { printf("Invalid interpolation range for pressure in UDF \n"); } /* Interpolation w. r. t Pressure for input pressure */ return exp((log(Cp10)-log(Cp1))/(log(P2)-log(P1))*(log(input_pressure)-log(P1))+log(Cp1)); } DEFINE_PROPERTY(cell_specificheat, c, t) { double cp; double input_temp = C_T(c, t); double input_pressure = C_P(c, t)+op_pres; if (input_temp > 288.15 && input_temp < 500.0 ) { cp = 0.24; } else { cp = compute_cp(input_temp,input_pressure); } return cp; } |
April 10, 2014, 11:02 |
Rep Power: 13 |
You should not use the DEFINE_PROPERTY macro for the specific heat.
Use the DEFINE_SPECIFIC_HEAT macro instead. Look it up in your UDF manual. Cheers |
April 10, 2014, 11:05 |
karthik kondaveeti
I have checked by using DEFINE_SPECIFIC_HEAT as well, but getting the same error Thank you |
April 11, 2014, 14:25 |
Rep Power: 13 |
I have checked your UDF more carefully and I think that your problem is that you have done an incorrect use of pointers.
I am not an expert in the usage of pointers, but a pointer is not a number actually, is a memory direction: so when you have written (*Acp)=0 and so on, I think that you meant "The value of Acp is 0", but what you have programed with the "*" was "The value of Acp is going to be stored in the memory position called 0". Check that. Cheers |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
multiphase UDF errors! | alexsatan | Fluent Multiphase | 0 | October 14, 2013 06:01 |
Various errors: Floating point, UDF compiling, etc | SEMC | FLUENT | 1 | September 6, 2011 10:08 |
Errors when Compiling UDF: error C2040/error C2099 | Julian K. | FLUENT | 1 | December 21, 2008 01:23 |
