Error: chip-exec: function "inlet_mf" not found
Old   March 21, 2014, 15:39
Default Error: chip-exec: function "inlet_mf" not found
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Dear all,
I wrote a simple UDF for a transient simulation. The mass flow inlet changes with respect to time :
#include "udf.h"
 DEFINE_PROFILE(inlet_mf,th,i)
   face_t f;
   real t = CURRENT_TIME;
   begin_f_loop(f,th)
       if(t <= 50)
          F_PROFILE(f,th,i) = -1E-08*pow(t,5) + 1E-06*pow(t,4) - 6E-05*pow(t,3) + 0.001*pow(t,2) - 0.014*t + 0.062;
              else
          F_PROFILE(f,th,i) = 0;
    end_f_loop(f,th);
The UDF is working correctly in my machine, when I transfer my case file with the UDF on a cluster, the following error is brought up :
I could not find a solution for my this error, note that the case file and the UDF source are located on the same folder, I also tried command like dos2unix. I am running out of option...
Thanks in advance,
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 24, 2014, 06:55
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi!
did you read the dat file before this error appears?
If so, read the dat file after compiling/interpreting.
Daniele
ghost82 is offline   Reply With Quote
Old   March 24, 2014, 16:09
diamondx's Avatar
Ghazlani M. Ali
Hi, thanks for your reply,
I interpreted the UDF on my machine, then I saved the case and data, and I transfered everything to the cluster. So what I do is just reading the case and data without interpretation. That being said, I could solve my problem, the issue disappeared when i change from PCMPI to MPI when loading FLUENT, I could not understand why, probably a bug between gcc and PCMPI
Thanks again,
Regards,
Ali
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 16:11
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
