UDF to change heat transfer coefficient with temperature diff |
March 17, 2014, 10:46 |
Yasser
Rep Power: 12 |
Dear, all
I am using FLUET to model a two concentric cylinders (Steady-state & 2-D). The gap between cylinders is filled with gas. I want to add a boundary condition (convection boundary) in the wall between the gas, inner and outer cylinder. I have a convection coefficient as a function of "Rayleigh No. = f(Th-Tc)" not a constant value. My problem is: - How to write a UDF for the convection coefficient which is a function in gas properties (thermal conductivity, visco, Cp, .....) and it is also a function in temperature difference (Th-Tc)?? - I mean how to write a UDF uses the material properties like (k, Cp, meu,....)???. and uses temperature diff. of two material (Th[solid]-Tc[gas])?? Thanks all |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
heat transfer coefficient udf | alighasemian | Fluent UDF and Scheme Programming | 0 | June 6, 2012 07:04 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 16:35 |
Flow around pipes - heat transfer coefficient on the wall of pipe | doodek | Main CFD Forum | 2 | November 23, 2009 09:48 |
Question on heat transfer coefficient!!! | Benny | FLUENT | 7 | June 7, 2005 10:25 |
