UDF to change heat transfer coefficient
Old   March 17, 2014, 10:45
Default UDF to change heat transfer coefficient
Yasser
eng_yasser_2020 is on a distinguished road
Dear, all
I am using FLUET to model a two concentric cylinders (Steady-state & 2-D). The gap between cylinders is filled with gas. I want to add a boundary condition (convection boundary) in the wall between the gas, inner and outer cylinder. I have a convection coefficient as a function of "Rayleigh No. = f(Th-Tc)" not a constant value. My problem is:
- How to write a UDF for the convection coefficient which is a function in gas properties (thermal conductivity, visco, Cp, .....) and it is also a function in temperature difference (Th-Tc)??
- I mean how to write a UDF uses the material properties like (k, Cp, meu,....)???. and uses temperature diff. of two material (Th[solid]-Tc[gas])??
Thanks all
eng_yasser_2020 is offline   Reply With Quote
Old   July 1, 2016, 10:47
Víctor
vpFluent is on a distinguished road
Hi eng_yasser_2020,
Did you find an answer for this problem?
Thanks
vpFluent is offline   Reply With Quote
Heat flux and Heat transfer coefficient sakil2k3 FLUENT 4 July 5, 2015 16:07
udf to define heat transfer coefficient zacfranki Fluent UDF and Scheme Programming 0 August 6, 2013 16:50
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
UDF for heat transfer coefficient Shankar Fluent UDF and Scheme Programming 9 February 18, 2013 10:13
error message cuteapathy CFX 14 March 20, 2012 07:45
