March 17, 2014, 05:43 |
Need some help for parallel UDF
Anurag
Rep Power: 12 |
Hi! this is my first post..
I am trying to simulating a simple transient heat transfer problem. I need to simulate the heat transfer across a vertical cylindrical heating element enclosed in a box with walls on four sides and inlet and outlet boundary conditions on top and bottom. I gave the outlet as pressure outlet and gave the inlet as time varied velocity profile. I don't have any problems for serial UDF but in order to use a finer mesh I need to write the UDF in parallel. The workstation has a quad core CPU. Can anyone provide me with appropriate tutorials for this?? I searced the web but everything looks so complex Thanks!! |
April 2, 2014, 18:38 |
Bill Wangard
You need to post the UDF, so we can see why it is not working.
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 08:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 22:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 05:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
