March 14, 2014, 06:10 |
reading profiles as input parameters?
Rep Power: 12 |
I have a doubt, I have a fournace with different input fuels, and I want to know wich is better.
I want to set some profiles (the whole profile(results.prof)of some experimental data I have) as input parameter, the profiles have inside matrix with x y z CO H N Vel (how fuels descompose). So I would be able to compare the results (level of pollutant of each fuel), my idea is something like this: read1(read profile1); read2(read profile2); readn(read profile n).. My input parameter should be read,and changing the value of read 1,2,3....n in workbench, it would be posible to comapre them. Now I can read it one by one in Fluent, with File/Read/Profile.. but, is it posible to set them as input parameter with scheme programming? Thank you all for your help |
input parameter, profile, scheme |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 02:47 |
[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised" | preibie | OpenFOAM Meshing & Mesh Conversion | 28 | March 29, 2017 05:56 |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 04:02 |
Parameters for multigrid solver | HaZe | OpenFOAM Running, Solving & CFD | 3 | January 28, 2012 03:05 |
Time-Varying Temperature Profiles | shepardsp | ANSYS | 3 | October 17, 2010 15:36 |
