Loop over define_profile
Old   March 13, 2014, 05:48
Default Loop over define_profile
Lukasz
lukasz0004 is on a distinguished road
I'd like to do for loop over dozens of faces in order to specify heat flux profile on each of them. This heat flux profile has different mean value for each face.
How should I do for loop over DEFINE_PROFILE?
for ( i = 1 ; i<=30 ; i++)
DEFINE_PROFILE(hf_profile_i, ft, var) - I don't know how to treat hf_profile_i that index "i" will be recognized in loop
float x[3];
float z;
face_t f;
float q0 = q[i];
begin_f_loop(f,ft)
F_CENTROID(x,f,ft);
z = x[2];
F_PROFILE(f,ft,var)= q0*sin(((z/0.02)*M_PI);
end_f_loop(f,ft)
Later in journal file I will do loop and prescribe heat flux profiles to adequate faces.
Thanks you for any help.
lukasz0004 is offline   Reply With Quote
Old   March 14, 2014, 05:10
pakk will become famous soon enough
It is not clear to me what you are trying to do here.
Do you want to have 30 different profiles for heat fluxes? Or do you want one profile that covers 30 different faces? Please explain what your variable i indexes.
pakk is offline   Reply With Quote
Old   March 17, 2014, 04:28
Lukasz
I'd like to have both. It means 30 different profiles of heat flux on 30 different faces. Indexes starts from 4 to 33.
Old   March 17, 2014, 04:43
It is still unclear what you want.
Do you want 900 different things? (900 = 30 x 30)
Or you do you want one profile that gives 30 faces each a different value?
Old   March 17, 2014, 05:08
Lukasz
I'd like to have one profile that gives different value on each face. For every profile q0 is unique (this is mean heat flux value). q[i] is defined as a matrix with mean values that corresponds to given face
Old   March 20, 2014, 08:14
If you would like to have one profile, then just define one profile.
There is absolutely no need to loop over anything.
Maybe you did not fully understand what a profile is, check it in the help.
heat flux udf, loop over define_profile
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Optimizing the solution of tridiagonal linear systems CCKM Main CFD Forum 14 March 14, 2012 08:40
Possible to loop a face thread inside a cell thread loop? MarcusW FLUENT 3 March 7, 2012 07:32
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
