March 6, 2014, 04:48 |
Error: "not a generic method"
tran trung
Rep Power: 13 |
hello every body
i'm setting up bolling model. i get error "Error: Internal error at line 7311 in file '..\..\src\prop.c'.Interphase_Heat_Coefficient: not a generic method Error Object: #f ". Why ?. have i do ? thanks you so much |
May 21, 2015, 15:26 |
thomas
Rep Power: 12 |
Hello, did you have any luck? I am getting the same error.
November 17, 2015, 04:05 |
Alessandro
Rep Power: 17 |
Hello!
Well, I am facing the same problem... Any advice? Thanks, A. |
November 17, 2015, 07:36 |
thomas
Rep Power: 12 |
I solved it starting the whole Fluent setup from scratch.
November 17, 2015, 07:38 |
Alessandro
Rep Power: 17 |
Hello Thomas,
do you mean without changing anything in your previous tentative setup? In my case I just restarted from scratch... maybe the third time will be the good one!! |
January 19, 2016, 10:45 |
Ram Kumar Pal
Rep Power: 11 |
Hello friends, I'm facing the same problem in boiling model. If anyone have found the solution, please help.
thanks in advance |
February 4, 2016, 04:00 |
Same Error
Balamuralo
I am developing a 3D boiling model and I am getting the same error as you guys previously mentioned. Any solutions ?
February 9, 2016, 01:38 |
Ram Kumar Pal
Rep Power: 11 |
See mass transfer mechanism under phase interaction dialogue box. Define mass transfer mechanism "from phase "liquid" to "to phase "vapor".
Integral representation of a generic function | gentela | Main CFD Forum | 1 | July 5, 2012 05:25 |
Generic case structure for iterative design process | capucsc | OpenFOAM | 4 | May 6, 2011 12:26 |
Is it possible to develop a generic solver for hyp. equations?? | shyamdsundar | Lounge | 1 | January 21, 2010 09:45 |
generic scalars in star | manuutin | STAR-CD | 0 | August 7, 2009 07:05 |
op_read error on parent context: generic socket fa | giovanni | Main CFD Forum | 0 | September 5, 2008 05:30 |
