How to define the UDS boundary conditions of electromagnetic of a plasma? |
March 5, 2014, 21:22 |
Peter Aestas
Rep Power: 13 |
Dear all,
i am working on a plasma problem. And i defined e-field potential phi and magnetic vector Ax,Ay,Az, as UDS,but problem is, i don't know all the boundary conditions of these UDS. For example, at cathode, i only know the value of Az, and the flux of phi,but don't know the conditions of Ax,and Ay. So i want to ask how to deal with the UDS boundary conditions you don't know?Should i set flux or value equals zero?if so, how to make sure it's flux or value i should set? |
March 11, 2014, 13:48 |
Yash Ganatra
Rep Power: 13 |
I would suggest you read the following thesis: 1. Modelling of Dynamic Arc Behaviour in a Plasma Reactor, Andreas Westermoen 2.OpenFOAM Simulation for Electromagnetic Problems, Zhe Huang, Chalmers The boundary conditions are defined here. Regards, Yash Ganatra |
March 12, 2014, 03:57 |
Peter Aestas
Rep Power: 13 |
Thank you so much!I will check it!
Linux commands to define boundary conditions at velocity-inlet & wall boundaries | saayo3 | Fluent UDF and Scheme Programming | 1 | June 29, 2013 13:33 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
HOW to define boundary conditions in DPM? | x.p.lee | FLUENT | 4 | May 31, 2003 10:12 |
How to Define Pressure Boundary Conditions? | Sheenu | Main CFD Forum | 4 | May 12, 2000 13:52 |
