Source (multi-step chemical reaction)
Old   February 15, 2014, 08:24
Post Source (multi-step chemical reaction)
Alexey
Laexzzz is on a distinguished road
Hello!
I have a question about UDF for chemical reaction modelling
Scheme of my reaction:
dA/dt = -k1*A[t]
dB/dt = -k2*R(0)[t]*B[t]-k2*Mm0[t]*B[t]
dR(0)/dt = k1*A[t]-k2*R(0)[t]*B[t]
dMM0/dt = k2*R(0)[t]*B[t]
dA/dt, dB/dt, dR(0)/dt, dMM0/dt is the change of components concentrations in time.
A[t], B[t], R(0)[t], Mm0[t] - concentration of the component at time t
k1 k2 is reaction rate constant
Components A and B are continuously received in the tube.
Next I will need to know the concentration of each component at the tube
How can I solve this system of differential equations?
What UDF should I use?
Define_source and DEFINE_UDS_UNSTEADY?
Thank you in advance
Laexzzz is offline   Reply With Quote
Old   July 1, 2015, 03:16
Sara28 is on a distinguished road
did you solve the Problem? Could you please explain how? It could be helpful for my task. Please contact me.
Sara28 is offline   Reply With Quote
[Other] OpenFOAM Installation for navalFoam sachinlb OpenFOAM Community Contributions 22 July 28, 2017 06:26
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
combustion, chemical reaction or turbulent source? sogen Main CFD Forum 0 July 29, 2005 23:41
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
