Writing txt file in an UDF
Old   February 2, 2014, 13:11
Default Writing txt file in an UDF
Sayan Bose
sayan_bose is on a distinguished road
I want to write the particle accelerations in a separate txt file, in a DPM_BODY_FORCE UDF, by performing a file operation, to do that I added this few line in the DPM body force UDF, which logically should have worked.
But after loading the udf, when I am executing calculation fluent is getting closed when the particle update is about to happen, and the txt files created doe not have any thing in them, they are just blank.
This is the code, which just show the file operation part along with the conventional DPM body force codes, please tell me where I have gone wrong and what should I do to correct it.
DEFINE_DPM_BODY_FORCE(particle_body_force,p,i)
FILE *x_comp;
FILE *y_comp;
FILE *z_comp;
real bforce,bforcex,bforcey,bforcez;
x_comp=fopen("x-comp.txt","w");
y_comp=fopen("y-comp.txt","w");
z_comp=fopen("z-comp.txt","w");
x=P_POS(p)[0]-xmag;
y=P_POS(p)[1]-ymag;
z=P_POS(p)[2]-zmag;
modr=............................................. ........
................................Denomx;
if(i==0.)
bforcex=bforce*unitsx;
Ax = bforcex/P_MASS(p);
fprintf(x_comp,"%g\t\n",Ax);
else if(i==1.)
bforcey=bforce*unitsy;
Ay = bforcey/P_MASS(p);
fprintf(y_comp,"%g\t\n",Ay);
else if(i==2.)
bforcez=bforce*unitsz;
Az = bforcez/P_MASS(p);
fprintf(z_comp,"%g\t\n",Az);
return((bforce)/P_MASS(p));
fclose(x_comp);
fclose(y_comp);
fclose(z_comp);
sayan_bose is offline   Reply With Quote
Old   February 3, 2014, 08:52
pakk will become famous soon enough
It can be that you still have the files opened in some editor (notepad or whatever). I think I did that once and then Fluent also shut down without warning.
pakk is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
